Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 100 of 106
Thread: Launch video/dvd/cd/audio via any drive letter
  1. #91
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    The CD indicator is for Audio. For an audio cd. If you insert mixed or video it won't light up the CD indicator. It's more like audio/video/dvd indicators. I noticed you autoplay media, but then your definition for playing audio for example is to open the ML menu? autoplay is more designed to play the media without popping up a menu?
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  2. #92
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by chevyn8 View Post
    Thanks for your help chevyn8, it is exactly my problem . My audio CD are seen like a mixed CD.
    I don't know why.
    Dfx4 use Autolaunch.exe who don't have this problem .
    But i want to use Medialaunch !
    What is the best ini file ith my setup ?
    Oct 2006
    small town nebraska
    Medialaunch is doing detection by content not by device. I will consider making a change that would include a notifier for CD, DVD, removable usb. maybe "video cd", "video usb", etc... Not sure how far to take it. On your cd showing up as mixed....what files are on that CD. I guessing during the scan that it's finding content other than audio?? For the ini, it just depends on what you need. The autoplay media was added so that if you put in audio media, it would automatically load and play it without user input. Put in DVD, it plays the DVD.
    This should get you a pop-up screen when media is inserted.....
    LOADMEDIALAUNCHSKIN=TRUE
    SKINTOLOAD=MENU;mlmenu.skin
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  4. #94
    May 2008
    Bordeaux, France
    Smile
    Thanks chevyn8 for your help again.
    It's a gain idea infact, to include a notifier for CD, DVD, removable usb . If it is possible for you , i shall like that .
    I have tried 2 différent CD and they are seed like mixed.
    I shall try other CD and see if i have the same issue .
    Thanks again
  5. #95
    Oct 2006
    small town nebraska
    In the RR config, what do you have listed for video file types and audio file types? Those are the files it's looking for to determine what kind of media it is?
    audiofiles=.mp3,.wma,.cda,.wav,.exe,.m3u,.pls
    videofiles=.asf,.avi,.m2v,.mpeg,.mpg,.nsv,.vob,.wm v,.mp4
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  6. #96
    Oct 2006
    small town nebraska
    The info the post previous would still be helpful. I have a test version for you to try. Please note, it has FORCECDFS option. If the filesystem on the media is cdfs it should set it to audio. Set that to TRUE and see if it sets your cd to audio. Also added a couple of indicators. Not sure how well those will work. To upgrade, all you need to do is replace medialaunch.exe and update the ini. http://n8sgarage.com/download/chevyn8/
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  7. #97
    May 2008
    Bordeaux, France
    Smile
    Hi chevyn8,
    I have just tested your last medialaunch version with RR already ON and no CD in the drive k:\
    With the FORCECDFS=TRUE , it see well that my cd is a audio CD, launch the audio screen, create a list, "SAVELIST;C:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm\TempPL.M3u".
    And nothing .
    My indicator is always off "CUSTOM_AUDIOIN" .
    If i run RR with a CD or a DVD already in my k:\ drive, medialaunch don't see that a CD is in the drive. !
    but the new IND run very well
    CUSTOM_DRIVETYPECDROMIN
    CUSTOM_DRIVETYPEREMOVABLEIN .
    How can I use it . They are just some indicators.
    I should like that medialaunch test (in option) if a media (cd,dvd,usb) are already in the drive when RR run and ask if i want to launch one of them !
    If I launch the command "menu;ML.skin", , i see well my cd or dvd or usb key in , but if i use the button load (with my udio cd) nothing is launched !
    Is it possible ?
    I upload my log file
    Attached Files Attached Files
  8. #98
    Oct 2006
    small town nebraska
    In the ini you can specify that medialaunch will ignore or run already inserted items:ONRRSTART=FALSE
    Not sure on the indicator as I see this on the log:
    SETIND;CUSTOM_AUDIOIN;ON
    As far as I know, that should turn on the indicator.
    These 2 commands should load the K: drive into a playlist and then open that skin.
    LoadList;K:\
    Load;audio_playerCWD.skin
    Yes it should be possible, as it works on mine
    What are the contents of the drive (I wonder because it seems to think it has audio and video), and what are your audiofiles and videofiles in RR? Will the CD play in winamp(or whatever you use for playing audio)
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  9. #99
    May 2008
    Bordeaux, France
    It's well my CD audio indicator !
    LoadList;K:\
    The CD is seen, the play list is created but empty !
    I have only .cda files.
    I have also used a CD audio make by me and i have the same issue .
  10. #100
    Oct 2006
    small town nebraska
    The log you sent indicates the program is working, setting the indicator and doing a loadlist for that drive.
    What are the contents of the drive (I wonder because it seems to think it has audio and video), and what are your audiofiles and videofiles in RR? Will the CD play in winamp(or whatever you use for playing audio)?
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. usb pen drive lost data, how can i recover it?
    By 0okami in forum General Hardware Discussion
    Last Post: 10-26-2006, 01:13 PM
  2. Hard drive dilema.... 2.5" or 3.5"?
    By 3Tripnip in forum General Hardware Discussion
    Last Post: 01-14-2006, 01:30 AM
  3. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 01:50 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 12:28 PM
