Page 11 of 11 FirstFirst ... 234567891011
Results 101 to 106 of 106
Thread: Launch video/dvd/cd/audio via any drive letter
  1. #101
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Cool
    Quote Originally Posted by chevyn8 View Post
    The log you sent indicates the program is working, setting the indicator and doing a loadlist for that drive.
    What are the contents of the drive (I wonder because it seems to think it has audio and video), and what are your audiofiles and videofiles in RR? Will the CD play in winamp(or whatever you use for playing audio)?
    Ok i have found my problem for the playlist .
    I used foobar .
    With winamp like player, the playlist is well created and the CD is well read .
    Can you add a possibility for foobar and the other players ? .
    Is it easy to add a connection web to the cddb database (like cdrip), for to see
    the title and the jacket , or it is to hard ?
    The CD's indicator don't run for me
  2. #102
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Medialaunch just supports RR and uses RR commands. It doesn't specifically support winamp. Will foobar outside of RR play your CD? It needs to be able to play outside of RR in what ever player you use before RR can play it.
    What indicator are you trying to use (what is it called) and send me another log file when you insert the CD. The last log file you sent showed SETIND;CUSTOM_AUDIOIN;ON, which means CUSTOM_AUDIOIN indicator is turned on....
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  3. #103
    May 2008
    Bordeaux, France
    Ok I have found my errror.
    I had CUSTOM_CDIN and not CUSTOM_AUDIOIN for the Cd's indicator !
    Thanks for your help !
    All is ok now
  4. #104
    Oct 2006
    small town nebraska
    1.11 released 3/2/2010
    Located here:
    http://n8sgarage.com/download/chevyn8/
    Added forcecdfs option. If it detects a cdfs filesystem it assumes it's audio--evidently some audio cd's have some video files on them?? Also added some labels:
    CUSTOM_DRIVETYPECDROMIN
    CUSTOM_DRIVETYPEREMOVABLEIN
    I use the removable indicator for a simple usb in/out indicator.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  5. #105
    Newbie LeonGR's Avatar
    Nov 2008
    Piraeus - Greece
    Hi, firstly thank you for your great work.
    I only have one problem with the reload of previous playlist when it have files with Greek characters in the filename or when the songs are in a folder with Greek characters in the folder name, it does not resume playing because it can not handle the Greek lang, the filenames after the playlist reload looks like this:
    C:\_TMP\Audio\? ?p???t? S?????? 2011\Sfa??a?a??s ??t?s - ?e? ?????.mp3
    Is there any possibility to fix this or to give me any way to solve this?
    Thank you again and hope for a response
  6. #106
    Oct 2006
    small town nebraska
    Not sure I can help the Media Launch just uses standard RR commands. Reload playlist does a loadlist of the previously saved playlist.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. usb pen drive lost data, how can i recover it?
    By 0okami in forum General Hardware Discussion
    Last Post: 10-26-2006, 01:13 PM
  2. Hard drive dilema.... 2.5" or 3.5"?
    By 3Tripnip in forum General Hardware Discussion
    Last Post: 01-14-2006, 01:30 AM
  3. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 01:50 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 12:28 PM
