Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 106
Thread: Launch video/dvd/cd/audio via any drive letter
  1. #11
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i know what you mean
    i have been using the loadcd batch files from LSX i think it was(can't remeber)
    to do the same. but i was thinking it would be good to combine the lot in this 1 script.
    as i find the batch to be good, its also a hit and miss for me, no big deal
  2. #12
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Just caught me before I left...I'll look at all that stuff. El Camino, the current scripts created by the latest version of autoit won't decompile. I haven't tried to decompile yours yet. One more question....
    $cmdlineraw will work with an already running script?
    thanks,
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  3. #13
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Quote Originally Posted by chevyn8 View Post
    thanks,
    !!bingo!!
  4. #14
    Oct 2006
    small town nebraska
    Quote Originally Posted by EL CAMINO View Post
    !!bingo!!
    How does a person send it to the running MediaLaunch.exe. If I run /Road Runner/MediaLaunch/MediaLaunch.exe testing....it grabs the 'testing' like it should using $cmdlineraw. How do I send it something else now that MediaLaunch is already going?
    thanks.....still haven't left yet.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  5. #15
    EL CAMINO's Avatar
    Jul 2005
    adjust to your needs.
    Code:
    $medialaunch=$cmdlineraw
    select
    ;from road runner, use - "RUN;$RRPATH$medialaunch.exe|play"
    case $medialaunch = "$play"
    $rr.execute("PLAY")
    ;from road runner, use - "RUN;$RRPATH$medialaunch.exe|exit"
    case $medialaunch = "exit"
    $rr.execute("CANCEL")
    endselect
  6. #16
    Oct 2006
    small town nebraska
    So I send a run command to an already running medialaunch.exe? When I try that it just attempts to start another instance of medialaunch.exe, then it exits because I have it set to only run one instance. I think I have some other ideas from the Find Drive letters script.
    Code:
    select
    $rr.execute("PLAY")
    endselect
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  7. #17
    EL CAMINO's Avatar
    Jul 2005
    sorry; i was thinking in another script; get my version, is in my signature "SOME TOOLS", the source code is there also, see the player section , and the function at the very bottom, if you need more help let me know.
  8. #18
    Oct 2006
    small town nebraska
    I have some things working pretty good...in the medialaunch skin drives appear and disappear as media is inserted and removed, with a label describing the type (video/audio/blank/unknown/dvd). Push on the button and it loads that media. My question, is what would an eject or stop media button do? Or is it a physical eject button that will actually eject the media. I'm thinking holding the button would eject it. How do you set up a button that has a duplicate function (hold).
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  9. #19
    EL CAMINO's Avatar
    Jul 2005
    Code:
    B,XX,XX,XX,XX,"COMMAND1_CLICK",@COMMAND2_HOLD@
    simple as that.
  10. #20
    Oct 2006
    small town nebraska
    Code:
    simple as that.
    Any simple commands to eject media via rr?
    thanks.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. usb pen drive lost data, how can i recover it?
    By 0okami in forum General Hardware Discussion
    Last Post: 10-26-2006, 01:13 PM
  2. Hard drive dilema.... 2.5" or 3.5"?
    By 3Tripnip in forum General Hardware Discussion
    Last Post: 01-14-2006, 01:30 AM
  3. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 01:50 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 12:28 PM
