You should never get that error though. Let me see what you have in skin.ini in your skin folder after you click the Audio button and it doesn't play. The MediaLaunch.ini included in the zip has Drive=D:\,E:\,H:\ Make sure when you add F it is F:\ (the last \ is important). The skin.ini in your skin folder will help greatly as it will have the commands for each button. The command should be AUDIO||LoadList;F:\
LinkBack URL
About LinkBacks
