Added carputer1's DFX skin mods to the download. Screenshot in the previous post.
http://n8sgarage.com/roadrunner/medi...DFX%20Skin.zip
0.98 Added DRIVEEXIST1 variable set to 0/1 if that drive exists. To have empty labels or specific labels if a drive doesn't exist at all. Example of what carputer1's skin using medialaunch:
CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
MediaLaunch for RR
Online Check for RR
Locker for RR
MediaLaunch for RR
Online Check for RR
Locker for RR
Shock v4 medialaunch skin by carputer1 and chevyn8:
MediaLaunch for RR
Online Check for RR
Locker for RR
Finished a shock v5 skin for medialaunch. It uses the font type/size/color from settings.txt (new shock v5 feature)
MediaLaunch for RR
Online Check for RR
Locker for RR
Latest version is now .99. Cleaned up the code some and increased the error checking when RR exits.
MediaLaunch for RR
Online Check for RR
Locker for RR
just got my new carputer, and was about to install tomorrow in the car , lucky i hav't disconnected it all yet form the test bench.![]()
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
Release version 1.0
Improved error trapping. If you were using .99, you just need to replace Medialaunch.exe
MediaLaunch for RR
Online Check for RR
Locker for RR
1.02 Added Ability to disable tray icon.
Pop-up skin commands MLRECENTLABEL and MLRECENTCMD
Also can select skin to load (not just medialaunch.skin)
This allows the skin to have a small pop-up menu that contains the media that was just inserted with a load/ignore buttons. But also have a separate medialaunch skin that has all the devices listed. I'll update the DFX 3.0 download to include the pop-up skin when I get it lookin' good.
The ini has changed so current ML users will need to replace the current one if they want to upgrade.
No bugs fixed in this release (don't know of any to fix)
MediaLaunch for RR
Online Check for RR
Locker for RR
Digital FX 3.0 MediaLaunch download now contains the pop-up menu skin....
http://n8sgarage.com/download/chevyn8/
MediaLaunch for RR
Online Check for RR
Locker for RR
Updated 1.04. It can create a custom list of inserted media, select from the list and play/eject....Example in the MediaLaunch DFX 3.0 skin download.
MediaLaunch for RR
Online Check for RR
Locker for RR
