Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 71 to 80 of 106
Thread: Launch video/dvd/cd/audio via any drive letter
  1. #71
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    1.05 released. Added some config buttons that make changes to the ini via the skin. Should be able to drop the generic skin files into your skin with medialaunch running and see it work.
    A button with "MENU;ML.SKIN||setvar;ml_communication;createc l"
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  2. #72
    Oct 2006
    small town nebraska
    1.06 Small change. The one button is pop-up on new media/auto load new media/off. The seconds button changes from 1-6 incrementing by 1 with every button press.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  3. #73
    Oct 2006
    small town nebraska
    Small update. Now talks to RideRunner.exe. Better detection of DVD's when using quick search. Don't update unless you use the new RideRunner.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  4. #74
    Dec 2008
    The download link is borken ... anyone can give a new link? thanks!
  5. #75
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    link is good just dl'ed it myself
  6. #76
    Jan 2007
    I'm having trouble getting this to work. The PC is a base install of windows, no a/v. Latest Ride runner installed.
    The skin displays "no media inserted". When I insert an audio cd, mixed content cd, thumb drive, or anything, windows autorun prompt opens up, but the skin sits there and doesn't change.
    Any help would be greatly appreciated.
    All files were extracted to riderunner\medialaunch
    Button to call medialanuch.skin
    "load;Medialaunch.SKIN||setvar;ml_communication;cr eatecl"
    Exectbl.ini had this added:
    "MEDIALAUNCH","Run;C:\Program Files\Road Runner\MediaLaunch\MediaLaunch.exe"
    Start-up commands had "MEDIALAUNCH" added to it.
    Here's the medialaunch.ini file
    Code:
    [Media Launch Settings]
    Drive=e:\,f:\,g:\,h:\,i:\
    DVDCOMMAND=DVD
    CDCOMMAND=AUDIO
    VIDEOCOMMAND=VIDEO
    MIXEDCOMMAND=AUDIO
    BLANKCOMMAND=
    UNKNOWNCOMMAND=
    ENABLEMIXEDMEDIA=true
    ENABLEBLANKMEDIA=FALSE
    ENABLEUNKNOWNMEDIA=FALSE
    ENABLEQUICKSEARCH=TRUE
    ENABLELABELEDMEDIA=TRUE
    LOADMEDIALAUNCHSKIN=TRUE
    SKINTOLOAD=MENU;MEDIA.skin
    RELOADPLAYLIST=true
    AUTOPLAYMEDIA=true
    SLEEPSECONDS=2
    PROCESSPRIORITYLOW=FALSE
    ONRRSTART=FALSE
    CREATELABELS=FALSE
    NOTRAYICON=TRUE
    Here's the medialaunch.skin file
    Code:
    RoadRunner Skin
    RRScreen MEDIA
    L,199,349,214,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN5;=No Media Inserted<<" ,"LEFT"
    L,199,288,213,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN4;=No Media Inserted<<" ,"LEFT"
    L,199,226,213,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN3;=No Media Inserted<<" ,"LEFT"
    L,199,166,212,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN2;=No Media Inserted<<" ,"LEFT"
    L,199,107,213,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN1;=No Media Inserted<<" ,"LEFT"
    L,464,349,79,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN5;<<=Load","CENTER"
    L,464,288,79,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN4;<<=Load","CENTER"
    L,464,226,79,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN3;<<=Load","CENTER"
    L,464,166,79,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN2;<<=Load","CENTER"
    L,464,107,79,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN1;<<=Load","CENTER"
    L,572,350,70,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN5;<<=Eject","CENTER"
    L,572,289,70,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN4;<<=Eject","CENTER"
    L,572,227,70,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN3;<<=Eject","CENTER"
    L,573,166,70,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN2;<<=Eject","CENTER"
    L,573,107,70,35,255,255,255,14,HandelGothic BT,"BYVAR;MEDIAIN1;<<=Eject","CENTER"
    L,163,349,83,35,255,255,255,14,HandelGothic BT,"=$MEDIALETTER5$","LEFT"
    L,163,288,83,35,255,255,255,14,HandelGothic BT,"=$MEDIALETTER4$","LEFT"
    L,163,227,83,35,255,255,255,14,HandelGothic BT,"=$MEDIALETTER3$","LEFT"
    L,163,168,83,35,255,255,255,14,HandelGothic BT,"=$MEDIALETTER2$","LEFT"
    L,163,107,83,35,255,255,255,14,HandelGothic BT,"=$MEDIALETTER1$","LEFT"
    B,315,411,165,72,"SETVAR;RELOADOLDPL;TRUE",
    L,366,422,116,33,255,255,255,14,"HandelGothic BT","=Reload",
    L,357,447,116,29,255,255,255,14,"HandelGothic BT,"=Play list",
    L,199,349,236,35,255,255,255,14,HandelGothic BT,"=$LABELMEDIA5$","CENTER"
    L,199,291,235,31,255,255,255,14,HandelGothic BT,"=$LABELMEDIA4$","CENTER"
    L,199,227,236,35,255,255,255,14,HandelGothic BT,"=$LABELMEDIA3$","CENTER"
    L,199,166,236,35,255,255,255,14,HandelGothic BT,"=$LABELMEDIA2$","CENTER"
    L,199,107,236,35,255,255,255,14,HandelGothic BT,"=$LABELMEDIA1$","CENTER"
    B,556,102,102,45,"$EJECT1$",
    B,556,159,102,49,"$EJECT2$",
    B,556,217,100,51,"$EJECT3$",
    B,556,281,99,53,"$EJECT4$",
    B,556,344,100,51,"$EJECT5$",
    B,156,342,394,54,"$CMDMEDIA5$",
    B,156,279,394,52,"$CMDMEDIA4$",
    B,156,217,396,51,"$CMDMEDIA3$",
    B,156,160,395,48,"$CMDMEDIA2$",
    B,156,101,393,47,"$CMDMEDIA1$",
    /STANDARD
    B,693,89,95,96,"MEDIA",
    B,691,308,98,97,"SETTINGS",
    B,691,537,96,56,"VOL+",
    B,579,536,98,56,"VOL-",
    B,239,537,98,56,"PREV",
    B,352,535,99,56,"PLAY",
    B,465,536,99,56,"NEXT",
    B,693,418,95,95,"LOAD;exit_menu.skin",
    B,11,536,99,56,"EXIT",
    B,126,536,99,56,"STOP",
    B,12,199,98,95,"AUDIO",
    B,12,88,96,97,"RADIO",
    B,691,198,98,96,"GPS",
    B,13,307,97,97,"VIDEO",
    B,12,417,98,95,"LOAD;TV.SKIN",
    L,692,19,92,44,255,255,255,22,"HandelGothic BT","TIME","CENTER"
    L,13,18,97,44,255,255,255,22,"HandelGothic BT","DATE","CENTER"
    END
  7. #77
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    what skin is that from, that looks to be a very old version, try the example skins that come with medialaunch script files,
    i take it you add medialaunch to your exectbl.ini onskinstart line or in rr.ini
    but try the test skins 1st and go from there
  8. #78
    Oct 2006
    small town nebraska
    The easiest is to use the pop-up ml.skin:
    Looks like you are opening the full screen skin file, which doesn't use the custom lists command.
    Right now, the latest version of RR has problems with multiple commands stored in a variable....which is how medialaunch works. Guino is working on the issue....
    Currently setting up MediaLaunch to work with VLC (optional in the ini), which is where I realized the issue with RR. Also will be making it more standardized per the plugin standardization rules--should be fairly easy to do.
    Also, It will hopefully be easier to run/install with any skin using the pop-up ml.skin file. ml.skin may be in the plugin folder instead of added to the skin.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  9. #79
    Newbie BloodyRootsSP's Avatar
    Feb 2007
    So Paulo - Brazil
    I cant get to work either, in my case it wont load the media at cd drive or pendrive. When I click the LOAD button, it goes to Audio_Player.skin and does nothing.
    Im not running the latest RR and Im on DFX skin.
  10. #80
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this may be the problem chevyn8 has mentioned in another thread , which has now been fixed by the RR team, which has just been released download latest RR and try it again.
    i know chevy & mitch have been working on the problem ..
  1. usb pen drive lost data, how can i recover it?
    By 0okami in forum General Hardware Discussion
    Last Post: 10-26-2006, 12:13 PM
  2. Hard drive dilema.... 2.5" or 3.5"?
    By 3Tripnip in forum General Hardware Discussion
    Last Post: 01-14-2006, 12:30 AM
  3. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 12:50 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 01:49 PM
  5. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 11:28 AM
