Help for Medialaunch with Carwings Lite
Hello all,
I try to use Medialaunch with the Carwings Lite skin but , i have some problems.
When I insert a DVD , I see well my DVD Indicator and my DVD is launched.
When i insert a CD , I don't see my CD Indicator and my CD are not launched.
This is my medialaunch.ini file:
Code:
[Media Launch Settings]
Drive=G:\,H:\
DVDCOMMAND=DVD
CDCOMMAND=AUDIO
VIDEOCOMMAND=VIDEO
MIXEDCOMMAND=AUDIO
BLANKCOMMAND=
UNKNOWNCOMMAND=
ENABLEMIXEDMEDIA=TRUE
ENABLEBLANKMEDIA=FALSE
ENABLEUNKNOWNMEDIA=FALSE
ENABLEQUICKSEARCH=TRUE
ENABLELABELEDMEDIA=TRUE
LOADMEDIALAUNCHSKIN=TRUE
SKINTOLOAD=MENU;mlmenu.skin
RELOADPLAYLIST=TRUE
AUTOPLAYMEDIA=FALSE
SLEEPSECONDS=2
PROCESSPRIORITYLOW=FALSE
ONRRSTART=FALSE
CREATELABELS=FALSE
NOTRAYICON=TRUE
I launch medialaunch in rr.ini:
Code:
startcommand=MEDIALAUNCH
I define the path in exectbl.ini:
Code:
/*************************************Auto Launch CD and DVD******************************
"MEDIALAUNCH","Run;$rrpath$Plugins\MediaLaunch\MediaLaunch.exe"
My test are on Vista with RR allready on !
Another problem.
If i have a cd on my drive and run RR, medialaunch is well launched but it don't see that a cd is allready on a drive .
With a dvd , the indicator is ok .
A LOADMEDIALAUNCHSKIN=FALSE or TRUE exist but i have not a medialaunch.skin file . Where can i found an exemple please ?
If I use this command:
Code:
MENU;ML.SKIN||setvar;ml_communication;createcl
I obtain that:
http://www.mp3car.com/vbulletin/imag...6c03538020.jpg
An big icon and the drive number:
this is my modified ml.skin file:
Code:
RoadRunner Skin
RRScreen ml
IDL,10
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L,404,171,72,25,255,255,255,13,"arial:b","=Reload","CENTER"
L,406,173,72,25,0,0,0,13,"arial:b","=Reload","CENTER"
L,403,193,75,29,255,255,255,13,"arial:b","=PlayList","CENTER"
L,405,195,75,29,0,0,0,13,"arial:b","=PlayList","CENTER"
L,404,244,72,21,255,255,255,13,"arial:b","=Refresh","CENTER"
L,406,246,72,21,0,0,0,13,"arial:b","=Refresh","CENTER"
L,482,244,79,21,255,255,255,13,"arial:b","=EXIT","CENTER"
L,484,246,79,21,0,0,0,13,"arial:b","=EXIT","CENTER"
L,404,123,72,28,255,255,255,13,"arial:b","=EJECT","CENTER"
L,406,125,72,28,0,0,0,13,"arial:b","=EJECT","CENTER"
L,406,57,68,26,255,255,255,13,"arial:b","=LOAD","CENTER"
L,408,59,68,26,0,0,0,13,"arial:b","=LOAD","CENTER"
L,486,75,71,22,255,255,255,13,"arial:b","byvar;ml_autoplayloadvar;=OFF<<=ON<<=ON","CENTER"
L,486,52,71,22,255,255,255,13,"arial:b","byvar;ml_autoplayloadvar;=play-pop<<=Autoplay<<=Pop-up","CENTER"
L,487,109,68,18,255,255,255,13,"arial:b","=update","CENTER"
L,489,111,68,18,0,0,0,13,"arial:b","=update","CENTER"
L,487,125,68,18,255,255,255,13,"arial:b","=seconds","CENTER"
L,489,127,68,18,0,0,0,13,"arial:b","=seconds","CENTER"
L,485,167,73,23,255,255,255,13,"arial:b","=Reload","CENTER"
L,487,169,73,23,0,0,0,13,"arial:b","=Reload","CENTER"
L,485,184,73,23,255,255,255,13,"arial:b","=Status","CENTER"
L,487,186,73,23,0,0,0,13,"arial:b","=Status","CENTER"
L,487,142,68,18,255,255,255,13,"arial:b","=$ml_sleepstatus$","CENTER"
L,489,144,68,18,0,0,0,13,"arial:b","=$ml_sleepstatus$","CENTER"
L,487,201,68,26,255,255,255,13,"arial:b","=$ml_autoreloadplayliststatus$","CENTER"
L,489,203,68,26,0,0,0,13,"arial:b","=$ml_autoreloadplayliststatus$","CENTER"
L,88,11,223,31,255,255,255,22,"arial:b","=Inserted Media","CENTER"
L,92,15,223,31,0,0,0,22,"arial:b","=Inserted Media","CENTER"
B,321,6,58,41,"UP",
B,19,2,60,45,"DOWN",
B,399,165,81,58,"setvar;ml_communication;reloadplaylist||EXIT",
B,398,221,82,60,"SETVAR;ML_COMMUNICATION;createcl",
B,481,221,82,60,"EXIT",
B,400,106,80,58,"SETVARBYCODE;ML_NUMBER;LISTTEXT||SETVAR;ML_COMMUNICATION;EJECT||EXIT",
B,399,45,81,61,"SETVARBYCODE;ML_NUMBER;LISTTEXT||SETVAR;ML_COMMUNICATION;LOAD||EXIT",
B,479,43,81,61,"byvar;ml_autoplayloadvar;setvar;ml_communication;autoloadskin<<setvar;ml_communication;autoplay<<setvar;ml_communication;autoplay",
B,479,103,81,61,"setvar;ml_communication;sleepseconds",
B,479,163,81,61,"setvar;ml_communication;autoreloadplaylist",
/, SD, Alignment, DisplayMode, IconWidth, IconHeight, Path, FileTypes, Show Extension
SD,00,00,50,50,"$rrpath$snes9x\roms","*.*",0
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
/, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
/S01,105,85,573,313,255,255,255,255,255,255,0,0,0,255,255,255,TRUE,20,#FONT#
SC,24,56,355,218,255,255,255,255,255,255,0,0,0,255,255,255,true,20,"arial:b"
/, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
IL,CL,RGBFF00FF,RGBFF00FF,* * * * * * * * * * * *,0,20,70
END
The SD,00,00,50,50,"$rrpath$snes9x\roms","*.*",0 is normal in this skin ?
Where is my error please !:confused:
