Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: RRMobile 0.3 Development
  1. #31
    Newbie VorTechs's Avatar
    Dec 2007
    Gloucester, UK
    Thanks for the report, I'll take a look on Monday and throw some more logging in to capture the incoming/outgoing streams so we can make sure things are being sent/received as we would expect.
    I notice that you have nothing in the 'Supported Commands' section of the profile. This was required by the original program, for reasons I didn't delve too deeply into and I didn't want to change things completely in case something broke. It might have something to do with your problem. Try pasting the unique commands together into that setting see if things start working.
    KimmyBean> Stu, you know that cybersex we had?
    KimmyBean> I'm pregnant!
  2. #32
    Jan 2008
    I added these lines, again I copied them from my working config for version 2.0
    This didn't help so after comparing the files I changed the "Use RTS=0" to "Use RTS=1" but once again this did not help.
  3. #33
    Aug 2006
    Just got round to trying this out on my Sony Ericsson W610i, and after a little tinkering around I got it to connect ok.
    RRMobile will read out the battery level and signal strength, along with the phone make and model.
    Apart from that I can't get it to actually make a call/hangup/answer etc..
    I've also noticed that the main RRMobile app doesn't exit cleanly.. I have to kill it from task manager before I can relaunch it again.. after exiting via the X button on the skin it will keep running in processes (not actually using a CPU time though..)
    Looks like a good start though!
    Looking forward to testing out some future versions.
  4. #34
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    how is this progressing? please dont let this die! its our only hope!
  5. #35
    Feb 2008
    COM port issues
    I am trying to get rrmobile running with my O2 XDA Orbit. My problem is with the com ports.
    On my bluetooth settings I am seeing the phone on com port 26 and when I run AT Sniffer this is confirmed. However I cannot set port 26 on rrmobile, the options only go up to 9.
    How do I
    a) change the bluetooth to use a lower comport
    b) get rrmobile to recognise com 26.
    Any help would be appreciated
  6. #36
    FLAC Griff1's Avatar
    Nov 2005
    You should be able to remedy that by overiding the port address...
    Go to "control panel" and then "system","hardware" and finally "Device manager" and locate your port in the list,right click on it and selct "properties" and then "port settings" now click on the advanced tab and it will display its current port number,click on that and you can change it to any unused port address.
    Before you do all that though just try adding the port number (26) to the RRMobile ini with the rest of them.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  7. #37
    Mar 2008
    Samsung SGH-i607 BlackJack
    I can't wait to try out your software! Any chance the source is posted somewhere?
    Check out the forum here for marvelous resources for this device. There are plenty of downloads, custom "cooked" ROMs, and a pre-release kitchen for those of you interested. Or simply flash your BlackJack to have all the BT profiles your RRMobile can stand! Compliments of our cook Da_G and our host TxCaesar.
    Why put up with a locked down AT&T update when we're already talking about WM 6.1 research?
  8. #38
    Newbie rogue212005's Avatar
    Apr 2007
    McPherson, Kansas, United States
    Forbidden from downloading from server?
    Can't think of a single cool thing to type here........
    Parts Acquired: 90%
    Configured: 50%
    Software: Not Even close!!!! Looking for a good phone software solution
    Fabrication and Install
    Screen Mounting Figured Out!
  9. #39
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
  1. CompactFlash Association Announces CF SATA Development
    By rijndael in forum General Hardware Discussion
    Last Post: 07-21-2007, 03:18 AM
  2. SD Development Environment
    By 06TC_OWNER in forum StreetDeck
    Last Post: 07-13-2007, 03:47 PM
  3. RRMobile makes RR disappear
    By rscherp in forum RR Plugins
    Last Post: 11-06-2006, 10:28 AM
  4. FS: Siteplayer Development Kit
    By jpx7777 in forum Classified Archive
    Last Post: 03-24-2006, 01:27 PM
