Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: RRMobile 0.3 Development
    Jun 2005
    I guess this has died too.... When oh when will we get a phone plugin that actually works? I'd pay $100 for the program at this rate! its just too long overdue... the technology is there, it just needs a genious to hack it apart and make it work.
    Newbie VorTechs's Avatar
    Dec 2007
    Gloucester, UK
    Although I don't actively have a phone working yet (left mine at home today!), I've started making some fairly heavy changes to RRMobile with a view to providing an update in the near future.
    The full list of changes that I have made so far:
    • Modified plugin structures to be class based (for transportability of data across the application)
    • Plugin configuration INI file reader re-written
    • Plugin configuration modified to read from a single file
    • Plugin starts with no default profiles configured
    • Plugin now writes a default configuration if none exists
    • Plugin no longer closes when phone not available
    • Plugin loads demo data of 100 contacts with random default numbers, when Com Port = 0
    • Clicking on 'Phone Status' icon when phone not available re-establishes communications
    The new configuration file looks a little something like this:
    Code:
    [Configuration]
    RRMSkinPath=C:\RoadRunner\Plugins\RRMobile\Skin\
    RRMLogLevel=0
    AvailableProfiles=1
    ActiveProfile=1
    [Profile 1]
    Com Port=0
    Baud rate=57600
    Timeout=5
    Use DTR=0
    Use RTS=0
    Wait Time=3
    Supported Commands=
    Unsupported Commands=
    Initialise Command=
    Vendor Command=
    Model Command=
    Call Answer Command=ATA
    Call Hangup Command=ATH
    Call Dial Command=
    Last Phone Book=0
    [Profile 1 \ Phone Book 0]
    Phone Book Name=Phone Book 0
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 1]
    Phone Book Name=Phone Book 1
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 2]
    Phone Book Name=Phone Book 2
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 3]
    Phone Book Name=Phone Book 3
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 4]
    Phone Book Name=Phone Book 4
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    [Profile 1 \ Phone Book 5]
    Phone Book Name=Phone Book 5
    Enabled=0
    Initialise Command=
    Open Command=
    Read Command=
    Terminate Command=
    I'll probably tidy up the names of the sections related to the phone books so they read a little more sensibly (ie Profile 1 \ Outlook Phone Book etc) and I'm going to see if I can get my hands on some old working mobiles for testing with.
    If you have RRMobile working currently, I'd appreciate a copy of your existing configuration files for a couple of reasons:
    1) To write a conversion routine to port over existing configurations
    2) To build a list of commands on a phone by phone basis to provide some basic templates to get people up and running quicker
    Anything you can provide, please e-mail me here!
    TIA.
    KimmyBean> Stu, you know that cybersex we had?
    KimmyBean> I'm pregnant!
    Dec 2007
    Gloucester, UK
    Demo screenshot of some demo data enclosed:
    Dec 2007
    Gloucester, UK
    Quote Originally Posted by Enforcer View Post
    Pulls out chair and sits down.
    Looks around but is disappointed as there is no sign of the blonde waitress from the other thread.
    One step at a time, I want to get a grip on what RRMobile is doing to then use it in a completely clean app.
    Dec 2007
    Gloucester, UK
    Just fixed a bug causing the plugin to hang when communicating with some phones.....
    Aug 2006
    Really looking forward to your release.
    If you need any testing done I'm happy to help out (I have a Sony Ericsson W610 & HTC Wizard - WM6)
    Will this be able to route audio through the PC (and pass the pc's mic as an input) as I've currently found nothing able to do this
    Cheers!
    Dec 2007
    Gloucester, UK
    This plugin isn't likely to be able to connect to the Audio Gateway (the bit that passes the audio over BlueTooth), certainly initially.
    I intend to write a new plugin where hopefully this will be achievable, although I'm still researching the subject. If I can prove the concepts further than I've gotten so far, then I'll expose the back-end of the new plugin to a new version of RRMobile.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    rrMobile relives
    Quote Originally Posted by swift_gti View Post
    Cheers!
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Aug 2006
    Quote Originally Posted by VorTechs View Post
    Excellent, thanks for your reply - I look forward to seeing how this develops!
  1. CompactFlash Association Announces CF SATA Development
    By rijndael in forum General Hardware Discussion
    Last Post: 07-21-2007, 04:18 AM
  2. SD Development Environment
    By 06TC_OWNER in forum StreetDeck
    Last Post: 07-13-2007, 04:47 PM
  3. RRMobile makes RR disappear
    By rscherp in forum RR Plugins
    Last Post: 11-06-2006, 11:28 AM
  4. FS: Siteplayer Development Kit
    By jpx7777 in forum Classified Archive
    Last Post: 03-24-2006, 02:27 PM
