View Poll Results: How long a time should the MPG be averaged over?
Voters
2. You may not vote on this poll
  • About 10 minutes
    0 0%
  • Hours
    2 100.00%
  • As long as possible
    0 0%
Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 111
Thread: Vag-Scope Heads Up Display / Front End
  1. #101
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If anyone has the files for this plugin, please pm me so I can host them (as the site is currently down).
    Ride Runner RR's Myspace
  2. #102
    Low Bitrate belmontboy's Avatar
    Oct 2003
    England (South East)
    UPDATE: i emailed this guy and he has reset his server
  3. #103
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Can do C# coding
    I can do C# coding and debugging, interested in adapting this to a gasonline engine. I am riding a VW Passat VR6 1997.
    Let me know where to begin, if possible.
    -Michael
  4. #104
    Mar 2007
    Maryland, USA
    Can do the conversion for Gasoline engines
    Quote Originally Posted by puter View Post
    I would bet money that it's pulling in the wrong blocks for a gas car.
    We can make this work for your car, but I honestly don't have the time to do all of the coding. if you are willing to do most of it, I can explain it over the phone while you look at it.
    It's relatively simple, I just don't have the time to chug through the code.
    I can do the C# canges for gasoline engines. I have a vested interest. Contact me.
  5. #105
    Mar 2007
    Maryland, USA
    I have tried several ways to use this in road runner, LOAD, RUNQ, ONSKINSTART all have quarks.
    Those of you with it tied in satisfactorily please give specifics, which files to edit (rr.ini, execTbl). Then what to change in the files again specifics where in the file, "very top" after "xxx".
    No fragments as that is how I come this point of asking for specfics.
    I am using DigitalFx 4.0 skin
    TIA
  6. #106
    Mar 2009
    hey guys, I've been watching this post for some time, and I've just registered to try to help
    I have a VW Suran (I think it's only for the south american market), but it is built with the VW Golf's 1.6l engine (not diesel)
    I was able to install all the files, I can now open road runner, and it opens VAGcom, but I don't see any info. As I read this is because it's not opening the correct meas blocks.
    I've never used C++, and I've never even seen it, but I'm willing to help resolve this for the gas users.
    If you can provide me with a quick tutorial, I can get the C++ installed and try to see if I can figure something out
  7. #107
    Dec 2007
    I would like to apologize to everyone for abandoning this thread.
    i had not realized that this thread was still active. I honestly have transitioned to the TDIClub thread I started because I could not monitor all the forums that I had this post on.
    Here is the tdiclub thread:
    http://forums.tdiclub.com/showthread.php?t=206330
    I will add a note to the start of my thread as well. If anyone still has followup please feel free to contact me via PM on tdiclub or via that thread, I promise that I will be much more responsive.
  8. #108
    Oct 2008
    Hello...I have a question.
    I have a Vag 409 wire with modification for run with INPA BMW.
    can I use this great plugins??
    Dec 2007
    That depends if the BMW has the same blocks for reading.
    There are two things that you would need for this to work:
    1) actual vag-com software (I use it for communicating with the ECU)
    2) The same block setup.
    Blocks are sets of four values that are read from the ECU, they are sequentially numbered and each block pulls in a different set of data. If those blocks are not exactly the same for your car as mine then it will not work.
    I doubt this software would work out of box for you, but if you do use real vag-com software from ross-tech then you should be able to modify the source that I supply to make it work.
  10. #110
    Nov 2010
    can you send me the source file to webmaster@scirocco.co.il
  1. Embed Visu when already running & in multiple screens?
    By swift_gti in forum Road Runner
    Last Post: 01-23-2008, 05:48 AM
  2. slingplayer embed problems
    By 1Munkey in forum Road Runner
    Last Post: 11-06-2007, 04:52 PM
  3. cant embed my app!
    By djmickyg in forum SkinBedder
    Last Post: 06-13-2006, 08:38 AM
  4. IG Nag screen/ embed issues FIX how to
    By liquid_smoke in forum RR Skins
    Last Post: 06-03-2006, 02:35 AM
  5. Will FD 1.0 embed into FrodoPlayer?
    By ayclens in forum FreeDrive
    Last Post: 05-13-2006, 11:57 AM
