View Poll Results: How long a time should the MPG be averaged over?
Voters
2. You may not vote on this poll
  • About 10 minutes
    0 0%
  • Hours
    2 100.00%
  • As long as possible
    0 0%
Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 111
Thread: Vag-Scope Heads Up Display / Front End
  1. #31
  2. #32
    Dec 2007
    I am having problems with getting a com port failure, I think it may be my failure but could anyone who is trying it confirm this? I think I may need to slow down the automation on vag-com startup, but it could also be my cable or onboard computer; Hopefully it's the software because both of those things are expensive
    I'll pull out the vag connection today and try hitting it with some de-oxit and see if that helps.
  3. #33
    Dec 2007
    Okay, I have done some bug fixes. The files at links 1 and 2 have been updated.
    Bug fixes:
    Fixed bug that caused program to exit after only 2 minutes
    Added code that waited for communications to be established before going into the block read section
    Added a 1 second delay after clicking on measure blocks before text fields are updated, this allows the form to load fully before the measure blocks are selected. Prior to this the automation occasionally ran too fast for vagscope causing a failure.
    Tom:: can you confirm that these changes are working for you?
  4. #34
    Feb 2008
    Graphics help
    Hey im willing to lend a hand in the graphics department if you need help making a nice skin for it.
    Im working on a road runner skin at the moment and will be making one for your app. so if you want i could make you one for release?
    Let me know.
    Little teaser
  5. #35
    Dec 2007
    I would be more than happy to include your skin with my releases. I will probably be keeping the current skin up as well simply because I like the simplicity of it, but I would be willing to help you develop yours.
    one note is that you may want to have the background executable be run when RR starts up rather than when you enter the skin for some technical reasons with the communications between the software and car. I will be making these changes to mine when I have time as well.
  6. #36
    Feb 2008
    Quote Originally Posted by puter View Post
    Will you eventualy implement support for guages and maybe some graphs output by vagscope?
    is that something thats possible?
    I think it would be very nice to have guages and would definetly make your app VERY popular as it could be ported to any frontend im sure...
  7. #37
    Dec 2007
    gauges are possible but definitely not easy.
    I would not know how to do it within roadrunner, you would have to create a standalone app and then import it into roadrunner.
    My original intent had been to do gauges but I abandoned it when i realized how hard it would be. If you were able to create gauges in RR I would be more than happy to include support in my code for them, but you have to figure out how to make it work and tell me what you need
    If you decide to go the standalone route, I will update the standalone code with my latest updates, but after that you'll probably have to maintain it...I don't have the time to maintain two seperate code bases :/
  8. #38
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can do rotating gauges in flash. You can do sliders (progress bar like) natively in RR.
    Ride Runner RR's Myspace
  9. #39
    Dec 2007
    Cool, Thanks guino. Honestly I like the simplicity of this design. If someone wanted to create a skin for people to use I would be more than willing to help them, but I don't really want to develop another skin
  10. #40
    Feb 2008
    Quote Originally Posted by guino View Post
    Guino i know hot to use flash relitavly well... how can i get flash animations to function with RR and this plugin?
    Any info would be very helpfull
  1. Embed Visu when already running & in multiple screens?
    By swift_gti in forum Road Runner
    Last Post: 01-23-2008, 05:48 AM
  2. slingplayer embed problems
    By 1Munkey in forum Road Runner
    Last Post: 11-06-2007, 04:52 PM
  3. cant embed my app!
    By djmickyg in forum SkinBedder
    Last Post: 06-13-2006, 08:38 AM
  4. IG Nag screen/ embed issues FIX how to
    By liquid_smoke in forum RR Skins
    Last Post: 06-03-2006, 02:35 AM
  5. Will FD 1.0 embed into FrodoPlayer?
    By ayclens in forum FreeDrive
    Last Post: 05-13-2006, 11:57 AM
