View Poll Results: How long a time should the MPG be averaged over?
Voters
2. You may not vote on this poll
  • About 10 minutes
    0 0%
  • Hours
    2 100.00%
  • As long as possible
    0 0%
Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 70 of 111
Thread: Vag-Scope Heads Up Display / Front End
  1. #61
    Apr 2008
    I sure am. When in road runner in the top right corner I click on vag scope. It then opens the .exe with the same error as if I opened it directly. I am using vag-com 409.1. Is it compatible with this version? Also it is the shareware version.
    Thanks,
    Josh
  2. #62
    Dec 2007
    Did you add the line to the RR.conf as per instructions?
    the vagScopeMode should be run at the time of RR startup.
  3. #63
    Dec 2007
    Any luck VWjet2001?
  4. #64
    Apr 2008
    Sorry I went home for a day and had dial-up. NOT going to put up with that. Anyway...I can't find the RR.config file. Does the new version have a different config file? Thanks
    Josh
  5. #65
    Dec 2007
    Quote Originally Posted by vwjet2001 View Post
    Josh
    For some reason I did not receive the email about this post, sorry I didn't respond.
    RR.config is in your roadrunner directory. Hopefully that helps.
  6. #66
    Dec 2007
    Notice of pending update.
    Just so everyone knows I'm in the testing phase for a fairly major update. Assuming I don't find any bugs (I have not so far) this will likely be the last code release.
    Added Features:
    1) Tank tracker
    2) Tank offset (plus or minus)
    3) Config screen to show above information and let you edit it in RR
    Bug Fixes:
    1) I now have it starting up vag-com MUCH more quickly.
    **You still need to be under 2k RPM
    2) Fixed error that would occasionally cause vagScopeMod to quit part way through running vag-com and leave vag-com sitting there.
    3) Fixed file writes for offsetting (I don't remember if this made it into the previous version or not)
    4) made it so that the vag-com button in the main RR menu actually works. It was not cloasing vag-com and restarting it. Now if you click vag-com it will close the currently running instance for the scope and start up the vag-com instance again. If you click vag-scope it will quit any running instance of vag-com and fire it up for the scope again.
    Potential Future Work
    1) The one thing on my plate potentially in the future is to figure out a way to have RR move back to the front after the vag-scope automation has finished. At this point I have not discovered a way to force the window back behind RR automatically, so you still have to click on RR to bring it to the front, in the future I may find a solution for this.
  7. #67
    Dec 2007
    Ok all, Sorry it took so long but I have finally uploaded the update. I wanted to do some pretty rigorous testing since this may be the last update for a while, and 2 tanks of fuel can take a while when you go 900 miles on one.
    Anyway, all of the updates in my previouse post have been done, including the future updates section.
    The following links have been updated in the original post: 1,2,3
    Also, I have added instructions to the original post for how to offset your MPG to get a more accurate average.
    I have also increased the accuracy of the instantaneous mileage.
    Finally, I wanted to give you all a little teaser. I have just ordered a chip from kermaTDI and they were pretty excited about this frontend and have discussed possibly working with me to develop a way to switch tunes from my frontend. I think that would be pretty damn cool and intend to pursue it if I can.
    Hope you guys enjoy the update.
  8. #68
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I'm having trouble getting it to run. The program crashes on launch. Road runner BV2 skin crashes on launch as well.
    VAG Com is installed okay because the VAG COM software sees the device. One thing is the BMV2.zip file in link 1 of the first post is corrupted or contains no data. I found it in the codepackage in the second link and tried that but same result.
    I'm sure I've overlooked something. Any ideas?
    Want to:
  9. #69
    Dec 2007
    use the first page, I should (and will) delete the second page thread, the first page is what I am maintaining now.
    I have downloaded and extracted all three links. They were zipped on a mac, so I think you may have to navigate a couple folders, but I was able to get all of these to work on both my pc and my mac
    If you are seeing all of the archives as corrupt it sounds like there may be something more going on with your system. Can you give me a detailed account of what errors you receive when you try to extract the files, and if you don't get any could you tell me what exactly you see in the extracted folder?
    Also, can you tell me what error you get when you crash? If you are not using the same skin as I made I would not be surprised if you did find that the vagScopeMod.exe crashed, it reads and writes labels from the skin.
    Finally, what version of vag-com are you running? i've noticed a pattern with ross-tech. it seems they like to change their window handles between versions. i don't know why they do this, but it makes my job harder. I think I may post the version that my software works with as well, hopefully ross-tech doesn't get after me for it...but I don't have the time to support their versions if they change the window name every time.
    so, here's the list of info I need and then I can start troubleshooting:
    1) What error do you get when extracting the archive?
    2) if no error, what do you see in the folder?
    3) What error do you get when vagScopeMod Crashes?
    4) Are you using a different skin from the one I made?
    5) What version of VagScope are you running?
    6) How far through automation does VagScopeMod make it before it crashes (does it fire up VagScope etc?
    Hopefully that will give me a good start on figuring out what's up.
    Also, make sure you read through the install steps closely, I know they're detailed but all the steps are necessary
    Thanks!
  10. #70
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by puter View Post
    The error is on link 1. When I attempt to extract it, I get the following error from Winzip: "The Compressed (zipped) folder is invalid or corrupt" There is no error on link 2 or 3. I shouldn't need link 3 unless I want to work with the source code, correct?
    Also, I tried downloading and extracting it on another system and it did not work. Got an end of signature error.
    P.S. - You're not making this program for the Mac, are you :-)?
    "VagScopeMod encountered an error and needs to close. We are sorry for the inconvenience"
    EventType : clr20r3 P1 : vagscopemod.exe P2 : 1.0.0.0 P3 : 483df378
    P4 : system P5 : 2.0.0.0 P6 : 4333ae87 P7 : 390a P8 : 288
    P9 : system.componentmodel.win32
    This is probably the issue since I couldn't extract the skin from the file.
    Release 805
    Nope. It never displays anything.
    Want to:
  1. Embed Visu when already running & in multiple screens?
    By swift_gti in forum Road Runner
    Last Post: 01-23-2008, 05:48 AM
  2. slingplayer embed problems
    By 1Munkey in forum Road Runner
    Last Post: 11-06-2007, 04:52 PM
  3. cant embed my app!
    By djmickyg in forum SkinBedder
    Last Post: 06-13-2006, 08:38 AM
  4. IG Nag screen/ embed issues FIX how to
    By liquid_smoke in forum RR Skins
    Last Post: 06-03-2006, 02:35 AM
  5. Will FD 1.0 embed into FrodoPlayer?
    By ayclens in forum FreeDrive
    Last Post: 05-13-2006, 11:57 AM
