View Poll Results: How long a time should the MPG be averaged over?
Voters
2. You may not vote on this poll
  • About 10 minutes
    0 0%
  • Hours
    2 100.00%
  • As long as possible
    0 0%
Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 71 to 80 of 111
Thread: Vag-Scope Heads Up Display / Front End
  1. #71
    Dec 2007
    Ok, well, it should not crash right away like that. I have that same version installed on my car computer now, so it can't really be the code.
    Can you make sure you have .net 2.0? That is necessary and could be the reason you are crashing. Once we make sure you have .net 2.0 we'll see if you get any further.
    You appear to be right on the zip file being corrupt, I must have missed it when I checked all the files last night. I am at work right now and don't have interenet access on my personal laptop, I will re-upload it tonight.
    Make sure you have everything installed in the default directories. I did not do any searching, so I assumed vag-com is in its default directory (C:\ross-tech\Vag-com I believe) and that Roadrunner is in its default directory (although I think this may not matter.)
    Also, I have release 704, so I can't guarantee that this will work for the release you have...but it should at least start vag-com. So try the first two things above so we can at least get it starting vag-com, if we run into more problems we will deal with them then.
    Let me know if any of that works.
  2. #72
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by puter View Post
    The new version of Vag-com is in C:\Ross-tech\VCDS rather than Vag-com. I changed the name of the folder but that didn't seem to help.
    I have version 2.0 of .net. When I ran the installer, it installed it last night. Checking the add/remove programs it shows that 2.0 is in there.
    Want to:
  3. #73
    Dec 2007
    Quote Originally Posted by Bugbyte View Post
    ok, I think this is a version issue with vag-com.
    Could you try to get vag-com version 704 and give it a shot?
    Also, I do need to check that you have a tdi. I have never tested this with a gas vw...but this isn't a concern until we actually get vag-com running.
    Edit:: if you wnat to try using your version of vag-com then make sure that the .exe in the folder is called VagCom.exe. So the full path should be C:\Ross-Tech\VAG-COM\VagCom.exe, Thing is that chaging the names like that could break vag-com itself.
  4. #74
    Dec 2007
    Just FYI, I have fixed the link to the skin. It should work fine now.
  5. #75
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    It's been renamed VCDS now. I can't find the old version 704 to try. I did get the skin okay, though.
    I renamed it but still crashes on launch, so I think I need version 704. Any ideas where I can get it?
    Want to:
  6. #76
    Dec 2007
    You have a message bug.
  7. #77
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Just to update - this is resolved. I needed the old version of Vag-Com for it to work.
    Want to:
  8. #78
    Dec 2007
    Version 704 works with this, unfortunately it seems that ross-tech likes to change executable names, window names, and directory structures with just about every release
  9. #79
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    It is likely just a window name/directory structure issue as puter said. I'm the one that posted that thread. Since installing version 704 fixed the problem, it is something we'll have to fix on our end.
    Want to:
  10. #80
    Dec 2007
    I do have some code in the configuration to allow for changing via the config file, but I don't think I put code in to deal with the .exe name and I believe that I may have forgotten to use a couple of the strings from the config
    There's a lot more code to the automation program than you would expect, I had to do a lot of workarounds.
  1. Embed Visu when already running & in multiple screens?
    By swift_gti in forum Road Runner
    Last Post: 01-23-2008, 05:48 AM
  2. slingplayer embed problems
    By 1Munkey in forum Road Runner
    Last Post: 11-06-2007, 04:52 PM
  3. cant embed my app!
    By djmickyg in forum SkinBedder
    Last Post: 06-13-2006, 08:38 AM
  4. IG Nag screen/ embed issues FIX how to
    By liquid_smoke in forum RR Skins
    Last Post: 06-03-2006, 02:35 AM
  5. Will FD 1.0 embed into FrodoPlayer?
    By ayclens in forum FreeDrive
    Last Post: 05-13-2006, 11:57 AM
