Page 6 of 6 FirstFirst 123456
Results 51 to 54 of 54
Thread: Skinners Helper and Debugging Tool By:JohnWPB & BlueZX3 [ Updated 12/05/08 ]
  1. #51
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Update...
    v1.84
    -Fixed Object creation error if running RR in VB IDE with it paused
    -Fixed Road name to Ride name
    -Added RR INI button to open up the RR.ini file
    Will also be included in the next RR release 3/??/09
    [Edit]
    File removed, see first post fo updated zip
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #52
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Here is the very latest version...
    v2.1.2
    -Added "Reloadkeytbl" command to the press & hold of the "Reload Exectbl" button
    -Added Restore RR to the press & hold of the "Minimize RR" button
    v2.1.1
    -Added RR Docs button to the RR Files, which allows direct access to all of RR's documentation right from skintool
    v2.1
    -Chagned Options button.
    -Added better & more support for RR related files: rr.ini, debug.txt, RR's Exectbl, Skin's Exectbl, skin.ini
    -Added Startup opt to the 'RestartRR' button if RR is not running.
    -Upd8d skintool PI
    -Fixed Skintool not remembering cmds on the next start when RR is running in profile mode
    -Fixed Slider opt update button not working
    -Fixed Clear & Use buttons in the option profiles
    v2.0
    -Added Options Menu, The "O" btn at top.
    -Added Multiple "profiles", a profile is a set of remembered cmds/vars/lbls/inds that can be loaded.
    Good for when working on multiple project to keep tested cmds more organized
    Loads last used profile on startup
    -Added Slider opt that replaces the bottom most group with a slider area
    -Added Support for up to 5 additional "Send Command" items, options are: None,+2,+5. Saves settings
    v1.86
    -Added Reload Exectbl button
    -Upd8d DLL to current plugin stds
    v1.85a
    -Added "ONCOMMANDINVALID" now translates to "Command Not Executed: xxxx" in live debug log
    v1.85
    -Added UAC compliant
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  3. #53
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    having issues when setting the get contents lines, if i set all 3 lines to var's and auto update, the script shuts down on me giving a -1 line error,
    any ideas
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #54
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Of course I have lots of ideas....
    I'll have to look..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Road Runner Installer and Updater (** Out Dated **)
    By W3bMa5t3r in forum Road Runner
    Last Post: 10-11-2008, 10:19 PM
  2. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 01:58 PM
  3. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 12:31 AM
  5. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 02:16 AM
