Page 1 of 6 123456 LastLast
Results 1 to 10 of 54
Thread: Skinners Helper and Debugging Tool By:JohnWPB & BlueZX3 [ Updated 12/05/08 ]
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Arrow Skinners Helper and Debugging Tool By:JohnWPB & BlueZX3 [ Updated 12/05/08 ]
    New Version v1.7 12/05/08
    - Re-Noted: getting indicator status
    - Re-Noted: logging of these clicks: Indicators, *Slider's (name and value(0-65xxxx))
    - Fixed control painting ( was leaving some artifacts )
    - Added "SkinTool_LogOn","SkinTool_LogOff" for turning on/off the live log instantly
    - Fixed bombing issue when using the AutoUpdate feature (now req's the dll to be used)
    Ver 1.5 09/19/08
    - remember the window locations from the last time that it was ran.
    - copy text from the degub log
    - Auto Update Labels / Variables
    - Ability to re-execute commands directly from the debug log by selecting and right clicking the command in the list
    - Ability to have the debug log in a separate resizable window (As seen in the screen caps below)
    - Remembering of any/all entered items
    - New "Edit Skin" button
    - New Dll file to coincide with the latest RR Build
    This is not an "end user" plugin by any means. It however is a tool to help when creating skins & debugging Road Runner problems. It is a simple way to see variable & label contents, as well as to set them to test skins in Road Runner.
    Instructions:
    Send Command: (The top 3 lines) are for sending commands directly to Road Runner. 3 lines have been provided to keep most used commands you are testing available with just one click.
    Restart RR: Does a complete shut down of Road Runner and re-starts it.
    Reload Skin: will reload the current skin to check any changes that you made.
    Reload Skin +: Same as Reload above, however this will return you to the skin that Road Runner is currently on, and not back to the main menu.
    Variable / Label Radio Buttons: Select either Label or Variable, Type the variable name, without the quotes or dollar signs, and press Get Contents, and the contents will be displayed .
    NOTE: Check marking "Auto Update" will automatically update the information whenever the label / variable changes in RR. The blue indicator you see in the screen capture below blink when the variable / label is set to auto update.
    Minimize RR: Minimizes RR to the task bar.
    Clear: Clears the current log file displayed on the screen (Added by BlueZX3)
    Pause Debugger: This will start and stop the debug text from scrolling automatically when viewing it. (Added by BlueZX3)
    Save: Save the debugging text to a file (Added by BlueZX3)
    Tabs at the top: To switch between the main window and the live debug. On the live debug window, you can also click "Separate Window" to show the live debug in s separate window.
    Attached Files Attached Files
    My Fiero Build Thread
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    very nice little helper plugin. I'm gonna get some use out of this!
    Live mp3Car Facebook Chat
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    So nice.
    I could have really used this when I was developing MMI, but it'll definitely help with my new skin.
    Thx!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yes, it is skinnable. See the Top menu bar, how it is transparent on my XP System
    Has anyone found any problems or suggestions. This was literally tossed together in about a half hour. I am sure there are something I may have overlooked that could come in handy.
    Aug 2006
    Sun Diego
    So far so good.
    Here's a suggestion:
    - List/DL highlighted item properties (postion, DLPATH, TRACKPATH, etc.)
    - More LABEL & VARIABLE slots like the "SEND COMMAND" buttons.
    Seems like you have the real estate for it.
    Aug 2006
    Sun Diego
    Ooooh...and how about a status window that displays information like the debug.txt file only it is generated during runtime so you can see what RR is doing?
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    I like this...a big time saver...a debug window would be even better, not complaining though, as this is a nice tool.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by chevyn8 View Post
    I take it that you never seen my live debug win plugin? It makes it a ton easier to see typo's and why something didn't work.
    John asked if the two of these could be combined or at least be able to use the data that mine shows in the bottom of his util.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Very nice, just started using it testing my skin changes
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  1. Road Runner Installer and Updater (** Out Dated **)
    By W3bMa5t3r in forum Road Runner
    Last Post: 10-11-2008, 10:19 PM
  2. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 01:58 PM
  3. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 12:31 AM
  5. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 02:16 AM
