Results 1 to 6 of 6
Thread: Button Changer Script
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    First release: Button Changer autoit script:
    The script creates a custom list from buttonlist.txt and makes changes to the button.txt INC file (the file names are changeable) based on selecting the new button. Read the included readme.txt. More details once MKIII is released, as it's included with that skin. Download MKIII and try it out...a pop-up menu with all the possible buttons in a scroll list.
    version .01 located here:
    http://n8sgarage.com/download/chevyn8/
    Also have buttonscript2....it's quicker, and doesn't have an autoit script. All the commands are in exectbl.ini, buttons choices come from buttonlist.txt, buttons are stored in skin.ini. Same download location.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i have uploaded a dummy skin.
    this is a fully working dummy skin for button changer, just drop it into your rr skin folder ,like you would if its a new skin, then select it either from within a in the skin changer screen of a skin or change your rr config, it will not launch an other skin files like audio player etc.
    but it will show the activation of the script the select and the change . You may need to change the paths in the Menu.skin, to where ever you put the script, at the moment the path is set for $rrpath$Plug in's\buttonchanger\buttonchanger.exe just change these lines .
    have fun with it
    just Press and hold the menu buttons and a popup should appear, make your selection and hit select.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Mar 2008
    Does not work!
    folder in derectory c:\road runer\buttonchanger\buttonchanger.exe
    Correctly?
    RUSSIA - WINER!!!
    Oct 2006
    small town nebraska
    You can put the script anywhere...the skin buttons need to point to that location. I keep it in the skin folder, as it has options that could be skin specific. MKIII isn't available for download yet....seeing how it's implemented will help.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you have to change the menu.skin
    Quote Originally Posted by pafftis View Post
    Does not work!
    Correctly?
    file in the sample skin, i hope thats not where you have put the script ,your path above as Road Runner is miss spelt. lol..
    if you want to keep the script there just take out the Plug in's\ out of the lines in the menu.skin file, otherwise like Chevyn8 say's stick it the skin folder its self and change the lines in the menu.skin to
    #BUTTON_CMD1#,@MENU;MENUB.SKIN||run;$skinpath$buttonchanger\buttonchanger.exe|1@
    the bit in red is what you need to change, you have to do this for each line.
    MKIII will be out soon just awaiting on some final details.
    Oct 2006
    small town nebraska
    You can download buttonchanger2. It's scriptless...all done with a few lines of exectbl.ini code. Functionality is the same, still uses buttonlist.txt, buttons stored in skin.ini. Not really a plug-in, more of a way to create dynamic buttons
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. Change Log
    By iamgnat in forum CarFrontEnd
    Last Post: 03-19-2008, 10:33 PM
  2. Could someone use a "album art organizer" script?
    By Sonicxtacy02 in forum RR Plugins
    Last Post: 04-17-2007, 10:46 AM
  3. Determining button highlight order
    By parksgm in forum StreetDeck
    Last Post: 12-19-2006, 10:38 AM
  4. iGmod Beta 2 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 05-12-2006, 02:52 PM
