Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 91 to 100 of 111
Thread: OVERLAY [screen loader]
  1. #91
    Low Bitrate JohnnySierra's Avatar
    Mar 2009
    Italy
    Thank you for the update.
    I'm just trying the old version with RideRunner and it doesn't work.
    So I come here and I found the new release of your plugin, I'm very happy.
  2. #92
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    enjoy
  3. #93
    Mar 2009
    Italy
    Ok, I'm experimenting your new version of ElcosMenu with RideRunner.
    I found that it's slower than the older version with RoadRunner. Do you have any suggestions?
  4. #94
    EL CAMINO's Avatar
    Jul 2005
    nothing was changed in the main code, i only add RideRunner.exe support, but i'll take a look.
  5. #95
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    I posted this problem in The gmpc overlay forum but being this is a Elcomenu deal I guess this would be more appropriate. I ran this overlay on previous XP system, since then, I have switched to Vista (upgraded to duo core) everything embeds and it loads correctly but it disappears behind the open window upon hitting any button inside Garmin.. if I alt tab it pops back up on top of the window but once again disappears upon next few button pressing.. Is this a issue with Vista?
    I use new Elco's ver 1.3 on DFX 4 and new March fresh install RideRunner.
    my setup RR.ini and Exec .ini's are listed on that forum I can't seem to link them here... Any Help would be appreciated. Thx
    heres the link to page 15 for my .ini's
    http://www.mp3car.com/vbulletin/rr-s...9-08-a-15.html
    Did it.. Done it... now I got to keep the neighbors kids away!!
  6. #96
    EL CAMINO's Avatar
    Jul 2005
    i hate vista, and i always downgrade to XP, sorry but i think vista is handling this script different than XP.
  7. #97
    Aug 2008
    owch that sux, I'm not a fan of Vista myself i dumbed it down, but my motherboard manufacturer don't support drivers for xp. Im gonna keep a eye on this any idea what area I should look at as far as scripting on the Vista end of it or process that possibly causes this? Any suggstions would be great. Particularly it vanishes behind window when I hit the "back button" in Garmin (not the overlay back). Other than that will work mostly. It works great sometimes, then other times it vanishes immediatly upon loading. ... completly random.. I even triied compatibility mode for elcosmenu.
  8. #98
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Red face My overlay
    Hi El Camino,
    I try to use your overly skin loader but I can't :
    I use the same files than in Garmin Overlay :
    in my exectbl.ini :
    Code:
    /**************************Menu Overlay pour RR Traffic***************************************
    "RRTRAFFIC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|rrtrafficol.skin"
    "RRTRAFFIC","LOAD;rrtraffic.skin"
    "RUNRRTRAFFIC","RUN;$SKINPATH$Scripts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic",rrtraffic.skin
    To launch my application :
    Code:
    "RRTRAFFIC||RRTRAFFIC_OVERLAY||RUNRRTRAFFIC"
    my rrtraffic.skin:
    Code:
    RoadRunner Skin
    RRScreen GoogleTraffic
    /, A, x, y, w, h, color;RGB
    A,-1,66,800,476,
    END
    and myrrtrafficol.skin:
    Code:
    RoadRunner Skin
    /POSX=0
    /POSY=0
    INC,Bottomtext.txt
    IMG,92,13,143,44,"Google.png",out
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B02,136,556,73,38,"ACTIVATE;GoogleTraffic||SENDKEY;{F6}","ZoomOut","ZoonOut"
    B01,64,554,70,39,"ACTIVATE;GoogleTraffic||SENDKEY;{F5}","ZoomIn"
    B05,213,556,63,38,"PREV","Prev/FW"
    B06,343,556,65,36,"PLAY",@STOP||PLAY@
    B08,280,556,59,37,"NEXT","Next/FF"
    B,478,556,66,37,"SHUFFLE",
    B12,677,9,122,56,"X_OVERLAY",""
    B,6,8,75,52,"MINIMIZE",
    B,544,552,67,41,"MIXER",@SKIN@,
    /, Y,  Back Slider file path
    Y01,"slider_battery\slider_*.gif"
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
    IL,PL,transparent.bmp,sel.bmp,end.bmp,2,50,80
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    SD,00,00,50,50,
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    /, I, x, y, w, h, Code;INDICATORCODES
    I,413,555,64,37,"MASTERMUTE"
    /, J, x, y, w, h
    I,623,7,50,57,"PHONE_CONNECTED_PHOCO"
    I,572,12,50,45,"ONLINE"
    END
    When I run the command, RR don't found RRTRAFFIC and RUNRRTRAFFIC.
    I want to create a menu overlay to see some buttons that i want to add over the window application.:
    GoogleTraffic & Microsoft Virtual Earth
    Do you have an idea please ?
    EL CAMINO's Avatar
    Jul 2005
    i dont see why? the only thing to check is your paths, also why dont use LOAD only. instead of RUN and LOAD, i would use this
    Code:
    "RUNRRTRAFFIC","LOAD;rrtraffic.skin;Traffic;$SKINPATH$Scripts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic"
    Code:
    and just call this.
    Code:
    "RUNRRTRAFFIC||RRTRAFFIC_OVERLAY"
  10. #100
    May 2008
    Bordeaux, France
    Quote Originally Posted by EL CAMINO View Post
    Code:
    Code:
    and just call this.
    Code:
    Thanks El Camino, I try these lines today ...
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
