4 Attachment(s)
OVERLAY [screen loader]
this is a very simple script that is capable to load any screen(.skin files) just like RR does, the big difference is that the background is not used, some people including myself needed this. heres some screenshot. same screen loaded using this little guy(top) and RR (bottom).
as of now only buttons are supported (is what i needed the most)i might include labels and indicators later on...
NOTE:skin(Teknik V2 created by valheru) hope is ok to use it as an example)
[[[labels enabled in BETA version]]]
1.25 out, memory leak and cpu usage fixed
1.3 out, RideRunner/RoadRunner Version
Very nice.
I can already image the possibilities in my new skin...
I know you can achieve the same effect using pink transparencies, but for some reason, I could never get that to work properly.
another big advantage using this is, that even if a screen is loaded on top of RR you still have control over RR, not possible using RR for the moment.(i think guino said something about adding this features to RR in upcoming releases not sure.)
Overlay in MKIII
I have this app in My skin on Destinator 7 works really well, slight delay in the button press.
but its the best so far.
in my D7 i have 2 OL graphic files 1 for map view , then you hit on/off button which will switch to the 2 image OL. so the menu's of D7 can be used .
http://i162.photobucket.com/albums/t...28_2007/ol.jpg
I wonder if an image can be overlayed on top of a visualization? That way i can have buttons for next and prev vis right on top of the visualization itself. I'm going to have to try it!
Thanks El C.
well now - I could hardly refuse you the use of TEK2 ... seeing as you put so much work into it's creation ...
wow.. great job El.... This could allow gps view with tremandous improvement if i understand correctly.. carputer1 just inspired me what i wanna do with my gps view...
basically, we can now put the buttons on the map as floaters and make them look transparent... Is it possible you can put a timer and make the skin go away? you know like valheru's popup..
1 Attachment(s)
This is Fantastic! It does load over the vis, those buttons actually work for prev. and next avs. Now i only have to go dig into skincommands to learn how to position the overlay.
Thanks El Camino, there's a lot that can be done with this.:whoo:
EDIT: nevermind the position, i loaded it in the truck and the buttons show where they should.
i'm glad you guys have found a good use for it, this is based in what i did for the carwings skin. part of the code belongs to LiquidSmoke, thats what i heard.
Nice work EL - Downloading now, AutoIT I take it?
