thanks Guino, My system is set up to keep CTS high until the power is cycled. On the bench I'm using a screwdriver to short 7 and 9 so I'm probably bouncing the switch. I'll try the code you posted and let you all know what happens.
Chris
Hi Chris,
The Exectbl you posted is the correct one, the (BLANK) one is an empty example file.
What is happening is:
-ONCTS_ON is executing the hibernate
-ONCTS_OFF is executing (I assume the switch is being reset)
-ONCTS_ON is re-executed (the switch was again triggered/redetected) this queues another "HIBERNATE" command for RR to execute (which ends up executing after you resume the first time (causing the second hibernate).
A simple solution is to use a variable to prevent this... try putting the following into exectbl.ini (replace the ONCTS_ON line you already have):
Code:"ONCTS_ON","BYVAR;HIBERNATED;DOHIBERNATE<<" "DOHIBERNATE","SETVAR;HIBERNATED;1||HIBERNATE" "ONRESUME","SETVAR;HIBERNATED;0"
Ride Runner RR's Myspace
Chris
Works perfect! Thanks Jebus for making the program and thanks Guino for helping this old man to get it to do what I want. The computer is a Nexcom fanless-
NEXCOM NISE 3100
I have an older version I found on ebay for a great price. Mine works on 8-30 volts and has been rock solid. As I mentioned before it doesn't have an ATX power switch header, I tried using windows built in UPS service to trigger hibernate and found that the UPS service triggers what's called critical hibernate which doesn't shut down everything properly. I was driving Mitch a little crazy with that one.... (sorry Mitch) Now I'll have to put this thing back in the car and hopefully when I get my Sirius and GPS hooked up it will still hibernate properly. At least hibernate is being triggered properly now.
The other surprise I found with this computer is only certian sound cards would work in the single PCI slot. That drove me a little nuts as only cheap soundcards would work and with the amount of time I spend in my car good sound is a must. I finally figured out that the PCI slot does not provide -12 volts. I didn't think anything used -12 volts anymore. I found a connector on the motherboard that allowed inputting -12 volts so I ran a wire from my bench power supply and my Soundblaster X-Fi finally worked. I had some Texas Instruments DC to DC converter modules so I used a PT6643P, 8 to 18 volt in, -12 volt out module to take care of that.
Thanks again men!
Is there a way to send commands to serialswitch by command line?
I'd like to use serialswitch via AI scripts just to set DTR ON/OFF and RTS ON/OFF so that I can turn on/off my amps in correct order to avoid THUMPS!
As long as you have this stuff on EXECtbl.ini (as described on install process):
You should be able to use RR's exec.exe tool to execute the commands:"DTRON","SENDMSG;SerialSwitch;DTR_ON"
"DTROFF","SENDMSG;SerialSwitch;DTR_OFF"
"RTSON","SENDMSG;SerialSwitch;RTS_ON"
"RTSOFF","SENDMSG;SerialSwitch;RTS_OFF"
(this of course required RR to be running)Code:exec.exe DTRON exec.exe DTROFF exec.exe RTSON exec.exe RTSOFF
Then you'll have to write your own command line application to send messages directly to the serialswitch plugin (as I don't believe serial switch itself has command line support for that) -- but maybe you should PM the author to see what he can do for you.
You're right. Maybe it can be useful to simply write new code to set on/off the status of DTR/RTS pins.
Serialswitch is a really good tool but I don't use it fully as I only need to turn on/off my amps, just after the OS is started (or resumed if it was suspended) and with the correct delays to avoid thumps. My idea is to have 4 separated commands (exe files) immediatly available to use them with hibernatetrigger.
I'll try to have a look on msdn. Any advice is higly appreciated.![]()
Wrote few lines of code and made a windows service.
Not tested in car yet, only in my testbed. Attached to this post for those interested.
When started, this simple service put the DTR value to high, waits 4 seconds then put the RTS value to high. That's exactly what I need, having 2 different amps in a series; I can now turn on the first amp then (after any transient) turn on the second amp with no thumps on my ears!
When the service is stopped it does the same in reverse and with a pause of 2 seconds only.
To install the service you'll need to use the installutil.exe of .net framework.
You can start/stop service using windows services console or by command line (or write some simple AI script just to have the ready exe files to run).
Enjoy![]()
update to my hibernation project- On occasion, when i hibernate while listening to Sirius, then resume, winamp will be playing along with Sirius. I just exit out of the Sirius screen go to the music screen then exit and go back to the Sirius screen. Winamp stops as soon as I reopen the Sirius screen. As a temporary fix I just paused Winamp. Isn't Winamp supposed to be closed when Sirius is playing? Why would it be starting itself like that?
