Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: locker
  1. #11
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    You can just fall over. It's way "Over-Engineered". Hopefully out of the box someone can call locker and lock the skin....then unlock it. As long as the basics work... The rest of the options are because I either wanted that feature OR wanted to know if I could make a feature work...
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  2. #12
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    wow there's now 4 lock programs available ! lol
    ALMOST 5 Hahahah! I started writing one a couple days before seeing this post. I was using one that would crash if accessed more than once, and just got frustrated and wrote one myself. (That and the fact the one I was using, you could just press ESC on the keyboard to get out of.... Kind of like "Windoze security! LOL I think it was Windows 95, at the user login screen, you could just press ESC to bypass it!)
    I see no need to release it, as there are plenty of options out there now! Great work on this one BTW!
    My Fiero Build Thread
  3. #13
    Oct 2006
    small town nebraska
    Thanks. One of the first tasks was how to disable ESC in autoit....just set a hotkey for ESC and have it do nothing. It also looks at the current rrscreen and if it's not the lock screen it will load the lock screen. If it sees the task manager it closes it. The next task is dumbing down the ini a bit.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  4. #14
    Oct 2006
    small town nebraska
    Added a few more features I wanted. I hope the ini makes more sense.
    Ini contains the alert volume and after alert volume.
    newcodeskin...entering a new lock code is done on a skin not the osk
    The skin example has buttons that display the status of email/audio alert, and each of the buttons toggle that status--the features I really wanted.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  5. #15
    Oct 2006
    small town nebraska
    Small Update. Now talks to Riderunner.exe. Don't update unless you use the new RideRunner.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  6. #16
    Aug 2007
    hi , that plugin working the email sender , i try with hotmail and gmail , with port 465 , but dont work , anyone know if that work ? thanks
  7. #17
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I think that isn't possible because gmail use the ssl crypt mode and don't give access to this feature
    chevyn8 can modif , i think it's autoit script for that
    A code example:
    Code:
    Func _INetSmtpMailCom($s_SmtpServer, $s_FromName, $s_FromAddress, $s_ToAddress, $s_Subject = "", $as_Body = "", $s_AttachFiles = "", $s_CcAddress = "", $s_BccAddress = "", $s_Importance="Normal", $s_Username = "", $s_Password = "",$IPPort=25, $ssl=0)
        $objEmail = ObjCreate("CDO.Message")
        $objEmail.From = '"' & $s_FromName & '" <' & $s_FromAddress & '>'
        $objEmail.To = $s_ToAddress
        Local $i_Error = 0
        Local $i_Error_desciption = ""
        If $s_CcAddress <> "" Then $objEmail.Cc = $s_CcAddress
        If $s_BccAddress <> "" Then $objEmail.Bcc = $s_BccAddress
        $objEmail.Subject = $s_Subject
        If StringInStr($as_Body,"<") and StringInStr($as_Body,">") Then
            $objEmail.HTMLBody = $as_Body
        Else
            $objEmail.Textbody = $as_Body & @CRLF
        EndIf
        If $s_AttachFiles <> "" Then
            Local $S_Files2Attach = StringSplit($s_AttachFiles, ";")
            For $x = 1 To $S_Files2Attach[0]
                $S_Files2Attach[$x] = _PathFull ($S_Files2Attach[$x])
                If FileExists($S_Files2Attach[$x]) Then
                    $objEmail.AddAttachment ($S_Files2Attach[$x])
                Else
                    $i_Error_desciption = $i_Error_desciption & @lf & 'File not found to attach: ' & $S_Files2Attach[$x]
                    SetError(1)
                    return 0
                EndIf
            Next
        EndIf
        $objEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
        $objEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = $s_SmtpServer
        $objEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = $IPPort
    ;Authenticated SMTP
        If $s_Username <> "" Then
            $objEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = 1
            $objEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/sendusername") = $s_Username
            $objEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/sendpassword") = $s_Password
        EndIf
        If $Ssl Then
            $objEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = True
        EndIf
        ;Update settings
        $objEmail.Configuration.Fields.Update
        ; Set email Importance
        Switch $s_Importance
            Case "High"
                $objEmail.Fields.Item ("urn:schemas:mailheader:Importance") = "High"
            Case "Normal"
                $objEmail.Fields.Item ("urn:schemas:mailheader:Importance") = "Normal"
            Case "Low"
                $objEmail.Fields.Item ("urn:schemas:mailheader:Importance") = "Low"
        EndSwitch
    ; Sent the Message
        $objEmail.Send
        if @error then
            SetError(2)
            return $oMyRet[1]
        EndIf
    EndFunc ;==>_INetSmtpMailCom
