Results 1 to 10 of 15
Thread: locker
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    locker
    Screen Locking program. Can lock multiple screens, multiple lock/unlock commands, multiple unlock/lock codes, alerts via email or text message...if your cell phone provider does email to text like alltel, audio alerts via you choice of .wav files and volume level. Some other stuff too--look at the ini. I've been using it for quite a while and it works for me. Generic example skin included. "Should" be able to drop it in any skin and call the locker script. 1234 is the default code.
    version 0.7
    Located here: n8sgarage.com
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Oct 2006
    small town nebraska
    Quick update, USB unlock can be from any number of drive letters. locker.exe and locker.ini changed. If you choose to use the usb unlock...
    Put a file on a usb stick with your code in that file
    In locker ini, add that drive letter and the name of the file
    When that usb stick is inserted, the lock screen is bypassed. With the latest update, if the screen is already locked, it will unlock the screen if the usb stick with the correct code is inserted.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Oct 2006
    small town nebraska
    oops, now it's updated with the latest...
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    we all make mistakes lol...
    Quote Originally Posted by chevyn8 View Post
    finally got this in the car, and i had someone test for me as i can not hear now,
    and my mate can not bypass the code and had ringing in his ears for atleast half an hour lol...
    so it works well thanks chevyn8
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    wow there's now 4 lock programs available ! lol
    Live mp3Car Facebook Chat
    Oct 2006
    small town nebraska
    yeah, I didn't know about a couple of them. That's OK, they are all a little bit different. Mine does exactly what I need The one here(mine) completely needs RR to function, I see some of the others don't. If I had GPS, I could probably add that too--may be as easy as adding something to the rrattemptscmd.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    "rrattemptscmd"
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Oct 2006
    small town nebraska
    Sorry, that's in locker.ini. When the amount of attempts(also in the ini) on the code have been reached...
    The contents of :
    rrattemptscmd=
    commandlineattempts=
    are executed, as well as the audio alert if enabled and the email alert if enabled. commandlineattemps could be a .bat file or any file that windows can execute. rrattemptscmd must be rr commands.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Oct 2006
    small town nebraska
    You may now also choose the unlock command you wish rr to execute via rr (this will override the locker.ini setting)
    This also works for the lock code and the entered wrong code command (will override the ini)
    example:
    "LOCKSKINBROWSER", "setvar;locker_unlockcommand;load;skin_browser.ski n||setvar;locker_code;55||setvar;LOCKER_WRONGCOMMA ND;exit||RUN;c:\program files\road runner\locker\locker.exe"
    Why exit the locker screen with the wrong code....If I'm just locking down the settings the user already has access to RR and a simple exit keeps them out of the settings while allowing them to still use RR. This was already possible in locker.ini (4 possible lock setups), now it can be done in RR (such as exectbl.ini) without a limit of 4.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Um...Me's staring to lean towards "Over-Engineered"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
