Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 93
Thread: RR application indicator
  1. #11
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Thanks blue , just looking through the code now, thats a good way of doing it, how many RR plugins have you made so far? seems to be u and festy that have made most of them?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #12
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, I have made a few... I just got more accustom to how to use the ext plugin and vb coding.
    But these are all simple ones, the media one is not so simple...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #13
    Nov 2006
    Wales, UK
    yea best of luck with that one, i used vb over 5 years ago, whats worrying is im better with autoit! tho i will send a donation your way when your done
    To monitor the press of a key (f2) to trigger an indicator like your using in the example you made for me, I was thinking of creating a seperate timer with something like this to trigger it
    Code:
    If KeyCode = vbKeyF2 Then Timer2.Enabled = True
    is this the best way?
    CarPuter Progress:
  4. #14
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by jonessc View Post
    Well, I'm like just the oppsite, I know AI fairly good now(~4yrs), and when switching between the two constantly is a big PITA! That and VB's pickyness about adding two strings together if they are not both of string type...
    Both JohnWPB & I will be demoing the Media plugin at todays meets...
    Code:
    Can't really answer that as I haven't gotton that far into VB yet...but I would think that something along those lines should work ok?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #15
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Any chance making this available to all?
    maybe put all the application names in rr.ini that uses the plugin to set an indicator for the respective application?
    I know I could really use this as a quick check to see if xport.exe is running, browsecovers.exe, etc. since I run RR as a shell.
    Not that you don't have enough on your plate already.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  6. #16
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, and I've just been handed another project by John...
    That could be done, I'd just have to make it more dynamic for number of programs and matching indicators...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #17
    Aug 2006
    Sun Diego
    kewl.
  8. #18
    Nov 2006
    Wales, UK
    The version blue done with the 3 indicators works superb, always handy to know if programs are loaded without having to check!
    Thanks again for the great work!
    Bit off subject now, but with all the new releases of GPS software (Garmin, IGO, Sygic etc) i have to edit the RRconfig to adjust GPS.
    I want to create a skin to set the GPS application from a list (in a RR skin), so it would have to replace the settings from the RR.ini file prior to the "GPS" button being pressed from menu.skin. then every time the "GPS" code is called it loads the set GPS app.
    Is a plugin the best way? or would an autoit script be better?
    Cheers
    CarPuter Progress:
  9. #19
    Aug 2006
    Sun Diego
    Cheers
    RR has a built in function to bring up a menu when you hit "GPS" so you can select from a menu of GPS apps.
    in rr.ini
    gpsmode=3
    this will bring up GPS_MENU.skin
  10. #20
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sal R. View Post
    in rr.ini
    gpsmode=3
    That won't help in this case as it brings up a menu with only the built in options.
    ie Mappoint, MapMonkey and external.
    Jonessc want's to select between different external ones.
  1. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 04:44 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
