Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 93
Thread: RR application indicator
  1. #21
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    That won't help in this case as it brings up a menu with only the built in options.
    ie Mappoint, MapMonkey and external.
    Jonessc want's to select between different external ones.
    i could create a seperate skin that could load like this:
    load;external_gps.skin;!Sygic DRIVE;C:\DRIVE_XP\drive.exe |-no-safety -r800x550;!Sygic DRIVE||ACTIVATE;Sygic DRIVE"
    but whenever "GPS" is called it will load whatever ive set in the RR.ini
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #22
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, this may not work and may seem mad but here goes.
    in Exectbl.ini
    "GPS","$newGPS$"
    in your skins skin.ini
    newGPS=<path to a GPS>
    the have the button code in your GPS menu skin change the variable newGPS to the path of the respective GPS program
    do one for each GPS you may wish to use.
  3. #23
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Not necessarily.
    You can use that menu to bring up other gps apps, but you'll have to create custom buttons for it:
    "LOAD;EXTERNAL_GPS.skin||RUN;<gpsapp1path&name>;<g psapp1windowname>"
    "LOAD;EXTERNAL_GPS.skin||RUN;<gpsapp2path&name>;<g psapp2windowname>"
    I've tried it. It works.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  4. #24
    Nov 2006
    Wales, UK
    in Exectbl.ini
    "GPS","$newGPS$"
    Quote Originally Posted by Sal R. View Post
    Not necessarily.
    Cheers guys. so if set the gpsmode=3 in RR.ini
    Then create a custom skin called GPS_MENU.skin with individual buttons like this (ignore the other buttons :
    if i code the sygic drive button with something like this:
    "LOAD;EXTERNAL_GPS.skin||RUN;!Sygic DRIVE;C:\DRIVE_XP\drive.exe |-no-safety -r800x550;!Sygic DRIVE||ACTIVATE;Sygic DRIVE" this will load sygic drive
    So when i call the "GPS" command again, will it just carry on using sygic until i close it or restart road runner?
    Cheers
    CarPuter Progress:
  5. #25
    Aug 2006
    Sun Diego
    Quote Originally Posted by jonessc View Post
    Cheers
    No. gpsmode=3 will ALWAYS bring up the GPS_MENU.skin.
    If you want it to behave the way you described above, you'll need to set a series of filters using SETVAR & BYVAR and add commands to your "GPS" button.
  6. #26
    Nov 2006
    Wales, UK
    I thought that was the idea of calling the gps_menu.skin (like the one in the picture) with the code you suggested
    CarPuter Progress:
  7. #27
    Aug 2006
    Sun Diego
    No.
    gpsmode=3 will bring up GPS_MENU.skin every time you click "GPS" button.
    The other button codes are for "calling" other GPS apps not native to RR (i.e. MappPoint, Destinator)
    If you want a function like you described above for calling GPS functions:
    You'll have to do something like this:
    ExecTBL.ini:
    Code:
    "GPS","BYVAR;gpsselect;MENU;GPS_MENU.skin<<GPSAPP1<<GPSAPP2<<GPSAPP3<<GPSAPP4<<GPSAPP5"
    "GPSAPP1","<load gps app 1 command line>"
    "GPSAPP2","<load gps app 2 command line>"
    "GPSAPP3","<load gps app 3 command line>"
    "GPSAPP4","<load gps app 4 command line>"
    "GPSAPP5","<load gps app 5 command line>"
    In GPS_MENU.skin:
    Code:
    BX1,...,"SETVAR;gpsselect;1||GPSAPP1"
    BX2,...,"SETVAR;gpsselect;2||GPSAPP2"
    BX3,...,"SETVAR;gpsselect;3||GPSAPP3"
    BX4,...,"SETVAR;gpsselect;4||GPSAPP4"
    BX5,...,"SETVAR;gpsselect;5||GPSAPP5"
    The code above will keep using a select app until you restart rr. Restarting will re-initialize gpsselect=0 at startup bringing up the menu for you to select again.
  8. #28
    Nov 2006
    Wales, UK
    Thanks Sal.
    Using that example when "GPS" is called the varibale will be set for as long as RR is running. Eg skin calls "GPS" you pick the application, then when "GPS" is called again it will continue to use the one i already selected (Dont want to have to pick the app everytime i switch screens back to the GPS sceen"
    CarPuter Progress:
  9. #29
    Aug 2006
    Sun Diego
    Thanks Sal.
    In theory, yes.
    I haven't tested the code as I put that together when replying...
  10. #30
    Nov 2006
    Wales, UK
    In theory, yes.
    :guineapig:
    Will let you know if it works
    Cheers
    CarPuter Progress:
  1. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 04:44 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
