Page 4 of 10 FirstFirst 12345678910 LastLast
Results 31 to 40 of 93
Thread: RR application indicator
  1. #31
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    One other way i was thinking is a simple autoit/vb program to edit the RR.ini that references the GPS before "GPS" is called in RR:
    RR.ini
    Code:
    [GPS]
    gpsmode=2
    mapmonkeypath=Click here to set path
    overspeed=55
    gpsport=9
    mappointmap=1
    mapcountry=United States
    mapcity=gpspath=C:\Program Files\Navigator7\PC_Navigator\PC_Navigator.exe
    gpsname=Navigator
    mapautozoom=true
    isunits=true
    usegpsserv=false
    gasfinderautorefresh=false
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #32
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    No need an external plugin.
    Use SETVAR/SAVETOINI to change $gpsmode$, $gpspath$, & $gpsname$.
    EDIT: Upon testing, this won't work on-the-fly if you use the "GPS" command since they are initialized by RR at startup.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  3. #33
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sal R. View Post
    Quote Originally Posted by Enforcer View Post
    Ok, this may not work and may seem mad but here goes.
    in Exectbl.ini
    "GPS","$newGPS$"
    in your skins skin.ini
    newGPS=<path to a GPS>
    the have the button code in your GPS menu skin change the variable newGPS to the path of the respective GPS program
    do one for each GPS you may wish to use.
    :WIS:
  4. #34
    Aug 2006
    Sun Diego
    in Exectbl.ini
    "GPS","$newGPS$"
    I tried that, but it didn't work.
    My suggestion was to use SETVAR/SAVETOINI to change rr.ini variables at runtime, per jone's idea, but the drawback of that was that those changes wouldn't take affect until RR is restarted and all the rr.ini variables re-initialized.
    Because gpspath/gpsname is initialized at start of RR, "GPS," by default, will be tied to rr.ini gpspath/gpsname values at startup, not runtime, despite changing it via SETVAR/SAVETOINI.
    For the "GPS" command to be dynamic while RR is running, "GPS" will have to be changed via ExecTBL.ini to:
    Code:
    "GPS","LOAD;<gps_skin_filename>.skin;RUN;$gpspath$;$gpsname$"
  5. #35
    Nov 2006
    Wales, UK
    Im still trying your original idea, the script was just an after thought if your plan didnt work.
    Thanks for helping Sal & E
    Will report and see if it works
    CarPuter Progress:
  6. #36
    Nov 2006
    Wales, UK
    Cant see anything in the skincommands but does RR support a command that closes & restarts it like blues RRconfig does from within a skin?
    CarPuter Progress:
  7. #37
    Aug 2006
    Sun Diego
    Reloadrr
  8. #38
    Nov 2006
    Wales, UK
    Reloadrr
    Thanks, it was in there didnt use that in the search tho!
    Have managed to use
    "SAVETOINI;GPSPATH;C:\GPS\PCN.EXE||SAVETOINI;GPSNA ME;PC Navigator"
    That writes direct to the RR.ini GPS setting
    Is it possible to read the same contents of RR.ini? ie the GPSPATH and GPSNAME sections to display as a label in RR?
    CarPuter Progress:
  9. #39
    Aug 2006
    Sun Diego
    Quote Originally Posted by jonessc View Post
    Have managed to use
    Yes.
    LXX,...,"=$gpspath$,""
  10. #40
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    All settings in the rr.ini file are avail as a variable to be used/displayed, and some can also be changed at anytime while rr is running(AKA "At Runtime")
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 04:44 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
