Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 93
Thread: RR application indicator
  1. #41
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Thanks Sal
    Heres a quick update, decided to add a menu to change the gps settings
    GPSSELECTOR.SKIN
    Code:
    RoadRunner Skin
    RRScreen "GPS SELECTOR"
    [GPS PATHS DISPLAY]
    L,17,254,543,64,,,,36,"Arial","=$gpspath$,"","CENTER"
    L,17,113,543,64,,,,36,"Arial","=$gpspath$,"","CENTER"
    [MAIN GPS SELECTION BUTTONS]
    /Pc Navigator 7.1
    B,584,23,208,93,"SAVETOINI;GPSPATH;C:\Program
    Files\Navigator7\PC_Navigator\PC_Navigator.exe||SAVETOINI;GPSNAME;PC
    Navigator","PCN 7.1"
    /Sygic Drive 7.0
    B,584,107,209,102,"SAVETOINI;GPSPATH;C:\DRIVE_XP\drive.exe |-no-safety
    -r800x530||SAVETOINI;GPSNAME;Sygic DRIVE","SYGIC 7.0"
    /Sygic Drive 7.5.229
    B,582,200,212,97,"SAVETOINI;GPSPATH;C:\DRIVE_XP\drive.exe |-no-safety
    -r800x530||SAVETOINI;GPSNAME;Sygic DRIVE 3ppc.net edition","SYGIC 7.5.229"
    /Sygic Drive 7.5.319
    B,583,288,211,97,,"SYGIC 7.5.319"
    /Igo 8
    B,583,378,211,99,,"IGO 8"
    [CONFIRM & BACK BUTTONS]
    /Select GPS
    B,583,494,102,93,"RELOADRR",
    /Back Button
    B,689,494,105,93,"MAIN",""
    /DISCARDABLE
    END
    This works so far, apart from I cant get the label to display the GPSPATH in the [GPS PATHS DISPLAY] SECTION!
    Files attached if anyone wants to try it
    just call it from a button with:
    "LOAD;gpsselector.skin"
    Attached Files Attached Files
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #42
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    if you want to display the changes you need to use
    Code:
    "SETVAR;GPSPATH;new path||SAVETOINI;gpspath;new path"
    and your label of course is
    Code:
    "=$GPSPATH$"
    same thing for gps name or any variable.and like blue said, some can take effect in runtime others don't, but there is always a way...
  3. #43
    Nov 2006
    Wales, UK
    Quote Originally Posted by EL CAMINO View Post
    Code:
    Code:
    "=$GPSPATH$"
    Cheers guys !
    That done the trick just one last finishing touch, in the picture (with red border) I want the top box to stay the same ie it reads the $GPSNAME$ once the skin loads, and when i press buttons it stays the same (until skin is reloaded)
    GPS SELECTOR.SKIN
    Code:
    RoadRunner Skin
    RRScreen "GPS
    [GPS PATHS DISPLAY]
    L,17,254,543,64,255,128,20,15,"Arial:b","=$GPSNAME$","CENTER"
    L,17,113,543,64,255,128,0,15,"Arial:b","=$GPSNAME$","CENTER"
    /Pc Navigator 7.1
    B,584,23,208,93,"SETVAR;GPSPATH;C:\Program Files\Navigator7\PC_Navigator\PC_Navigator.exe||SAVETOINI;gpspath;C:\Program Files\Navigator7\PC_Navigator\PC_Navigator.exe"||SETVAR;GPSNAME;PC Navigator 7.1 (Saved)||SAVETOINI;GPSNAME;PC Navigator","PCN 7.1"
    /Sygic Drive 7.0
    B,584,107,209,102, "SETVAR;GPSPATH;C:\DRIVE_XP\drive.exe |-no-safety -r800x530|||SAVETOINI;gpspath;C:\DRIVE_XP\drive.exe |-no-safety -r800x530||SETVAR;GPSNAME;Sygic Drive 7.0 (Saved)||SAVETOINI;GPSNAME;Sygic DRIVE", "SYGIC 7.0"
    B,582,200,212,97,"SETVAR;GPSPATH;C:\DRIVE_XP\drive.exe |-no-safety -r800x530|||SAVETOINI;gpspath;C:\DRIVE_XP\drive.exe |-no-safety -r800x530||SETVAR;GPSNAME;Sygic Drive 7.5.229 (Saved)||SAVETOINI;GPSNAME;Sygic DRIVE 3ppc.net edition","SYGIC 7.5.229"
    B,583,288,211,97,"SETVAR;GPSPATH;C:\DRIVE_XP\drive.exe |-no-safety -r800x530|||SAVETOINI;gpspath;C:\DRIVE_XP\drive.exe |-no-safety -r800x530||SETVAR;GPSNAME;Sygic Drive 7.5.319 (Saved)||SAVETOINI;GPSNAME;Sygic DRIVE","SYGIC 7.5.319"
    /Igo 8
    /Select GPS
    /Back Button
    /DISCARDABLE
    END
    CarPuter Progress:
  4. #44
    Nov 2006
    Wales, UK
    Im guessing it can't be done?
    CarPuter Progress:
  5. #45
  6. #46
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by jonessc View Post
    Cheers guys !
    Change the label w/ the red box to read;
    LXX,...,"=$currentgpsname$"
    Add this line to ExecTBL.ini:
    "ONSKINSTART","SETVAR;currentgpsname;$gpsname$ "
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  7. #47
    Nov 2006
    Wales, UK
    Quote Originally Posted by Sal R. View Post
    Perfect, that did the trick.
    Thanks Sal
    CarPuter Progress:
  8. #48
  9. #49
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    Sorry, I was too lazy to give you all the info.
    :.Also known as spoon feeding
    It's the thought that counts
    CarPuter Progress:
  10. #50
    Aug 2006
    Sun Diego
    heh...that's why I didn't respond initially. after all the discussion, I figured you'd figure it out after Enforcer's response.
    Then I saw your other post...lol.
  1. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 04:44 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
