Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 93
Thread: RR application indicator
  1. #51
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Sal R. View Post
    heh...that's why I didn't respond initially. after all the discussion, I figured you'd figure it out after Enforcer's response.
    Then I saw your other post...lol.
    I would have never thought of using the exectbl.ini, this is all new to me
    Any of you want to use the final release for your skins?
    Thanks Sal, Enforcer & Blue for your help!
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #52
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I might nick the code as a option for people if they want it, but I can't see many people switching between Navigation software.
    But I feel it has been a good learning experience for you
  3. #53
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    Yea, its been interesting, photoshop is a mouthfull to get into, and the RRskin editor just takes a bit of getting used to and knowing what to type in the buttons
    Speaking of which...
    In your skin E you use external_gps, and then you use a external_gps_full to re-embed the GPS in another skin with code:
    Code:
    "LOAD;gps-full.skin;FreeDrive;$gpspath$;FreeDrive",""
    Is it possible to do the same using the details from the rr.ini, ive tried this, but it didn't work (loads but the gps app doesnt re-embed)
    Code:
    "LOAD;EXTERNAL_GPS_FULL.skin;$gpspath$;$gpsname$"
    CarPuter Progress:
  4. #54
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by jonessc View Post
    Code:
    Code:
    Try
    Code:
    "LOAD;$gpsname$;EXTERNAL_GPS_FULL.skin;$gpspath$;$gpsname$"
    or
    Code:
    "LOAD;navigation;EXTERNAL_GPS_FULL.skin;$gpspath$;$gpsname$"
  5. #55
    Nov 2006
    Wales, UK
    Try
    Code:
    or
    Code:
    Thanks E, but neither didnt seem to do anything, i really should learn to walk before running
    CarPuter Progress:
  6. #56
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You people haven't looked at your RR Manual have you???
    proper load command is "Load;<skinfile to load>;<text to be spoken;<run command>;<title of window to embed>"
    The correct command would be:
    "LOAD;EXTERNAL_GPS_FULL.skin;;$gpspath$;$gpsname$"
    Correction in bold
    Nothing new here, this hasn't changed in..............
    .... forget it, as its been too long..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #57
    Nov 2006
    Wales, UK
    Theres an owners manual?
    That worked perfectly, cheers Blue
    CarPuter Progress:
  8. #58
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes there is but appearently no one ever looks at it when they can't get something they know should work to work...
    As that is all I did
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #59
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ooops stuck my extra command in the wrong place.
  10. #60
    Newbie Lucifer's Avatar
    Aug 2004
    Belgium
    Indicators extension in vb.net
    I'm trying to adapt the source for the indicators extension plugin. The problem is this source is in VB6 and I only have VSStudio 2005 Pro. Which of course converts the project into a .NET project.
    I tried building a new DLL project using a Class Library project in VSS2005 but I can't get it to work with RR.
    I can register the .NET DLL (it has COM wrapping enabled), but it's like RR doesn't see it.
    (my vb.net project try is at : www.pxlstudio.be/templates/ProcessIndicators.rar)
    Morex 3688 (Via MII10000 - 512Mb - 2,5HD 30Gb DVD+RW)
    CarTFT Motorized 7" In-dash Touchscreen
    CNX 1260
    Current Status: Skinning !
  1. Replies: 70
    Last Post: 10-15-2007, 05:21 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  3. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 03:44 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
