Page 12 of 18 FirstFirst ... 23456789101112131415161718 LastLast
Results 111 to 120 of 175
Thread: VLC plugin
  1. #111
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by pincopallo69 View Post
    VLC support...Simply Wonderful!!!!
    Are there any video or videobrowser skin to study?
    I've got some problem to send a selected item from a list (/S) to VLC application.
    I've tried, but browser launch winamp video window.
    When using this thread's VLC plugin you MUST use the skin commands from this plugin. This plugin is advanced and requires you to follow its instructions to get it to work correctly.
    If you just want VLC with basic support working on any existing (unchanged) skin you should use the VLC plugin from the installer.
    Ride Runner RR's Myspace
  2. #112
    Jun 2009
    Thanks Guino for quick response.
    I actually work on Crystalsilver Skin (Dalailama's creation) and your last edition of RR with VLC plugin set.
    There's no problem to set and launch VLC from ExecTBL.ini.It find my VIDEO directory and start play video.
    It point directly to $vlcvideopath$ by simply adding:
    "VIDEO","PAUSE"||LOAD;VLCVIDEO_PLAYER.skin;VLC;C:\ Programmi\VideoLAN\VLC\VLC.exe|$vlcvideopath$;Lett ore Multimediale VLC".
    vlsvideopath is set on Skin.ini file to a video file directory on my HD.
    I'd like to realize a VLCVIDEO_BROWSER to open file from a selection list.(like Dalailama does in his post http://www.carputer.it/showthread.php?t=7611)
    I read your VIDEO .doc directory for VIDEO plug-in, but i didnt' understand what are new command to use.
    By the way on web I haven't found nothing to make an easy video file selection directly by VIDEO_skin.
    It's Hard but I'll search again. If you have another link please post me.
    ThanKs again for your good job with RR.
  3. #113
    Jun 2009
    I've found some new information about VLC Skin Editor.
    So I'll try to make a VLC Skin in Crystalsilver style.
    I could use VLC native playlist function to search, load and manage video file like I actually do with Igo8PC navigator.... and works go on, ...maybe!!
    ...since someone makes something better!!
  4. #114
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Please note that if you're using the VLC player that comes with RR, you should NOT be talking about it in this thread -- this one is a separate VLC plugin (NOT the one that comes with RR). For discussing functions/features for the VLC player that comes with RR, you should open a new thread OR post in the Video Player's thread - thanks for understanding.
  5. #115
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    Hello,
    I know that this plugin is not finished yet, but would it not be possible to add some options.
    Consider whether it would not be possible to adjust the EQ of vlc and volume of the preamp, because I found some video saturartions evil and fortunately it impossible to lower the preamp.
    Even lowering the master at 1%, we still hear a saturation in the bass.
    Does this change is being studied? because there is a keyboard shortcut to lower the preamp volume in VLC ...
    Thank you.
  6. #116
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Vlc crash RR when i use Zoom
    Hello all,
    I use Vlc for the video . When i use the zoom , sometime , not always , RR crash !
    Specially when i want to read a xvid file and at the video's end !
    Do you know this problem please ?
    RR = 1/12/2009 .
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Haven't seen this problem. What version of VLC are you using ? Does it show any error message (can you take a screenshot) ?
    Quote Originally Posted by pierrotm777 View Post
    Hello all,
    RR = 1/12/2009 .
  8. #118
    Jun 2007
    I have karaoke files
    Can I add command to choose left channal in VLC Vdo player on RR ?
  9. #119
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by anuchit View Post
    Not in this plugin but I think your talking about Guino's native support for vlc in RideRunner. Better to post in that thread.
  10. #120
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    lombospirit, any chance you can update this to use the latest vlc version?
    i think this can be useful as a DVB-t player (vlc can play DVB-t nicely)
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
