Page 13 of 18 FirstFirst ... 3456789101112131415161718 LastLast
Results 121 to 130 of 175
Thread: VLC plugin
  1. #121
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Nomader View Post
    lombospirit, any chance you can update this to use the latest vlc version?
    i think this can be useful as a DVB-t player (vlc can play DVB-t nicely)
    Can take a look. Shouldn't take long
  2. #122
    lambosprit's Avatar
    Sep 2006
    UK
    not so easy. Seems the latest vlc has a problem with vb6. I can do it with .net. Would that be ok?
  3. #123
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i don't want to get you into much trouble.. it would be ok for me
  4. #124
    lambosprit's Avatar
    Sep 2006
    UK
    try this one.
    Attached Files Attached Files
  5. #125
    Apr 2006
    Greece
    that was fast..thanks..can you provide me a test skin, as the installer does not install any skins, though it shows that it does
  6. #126
    lambosprit's Avatar
    Sep 2006
    UK
    the only test skin I have is for freedom ultimate and it doesn't embed as I use it to play videos for my daughters in the back of the car.
  7. #127
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    The skin that arrive with your plugin are for rrskype ?
  8. #128
    Apr 2006
    Greece
    Quote Originally Posted by pierrotm777 View Post
    i think he just used the intaller from his other plugin RRsype.. i would have to find time to make a test skin..although as soon as i run the EXE. it crashes with an error
  9. #129
    lambosprit's Avatar
    Sep 2006
    UK
    Good guess. Thats exactly what I did. Whats the error your getting? You can test it by setting a valid path to a video in the rrvlc.m3u file and it should just start playing.
  10. #130
    Apr 2006
    Greece
    Quote Originally Posted by lambosprit View Post
    i did but i get the same error..when running rrvlc.exe rr starts then boom i get the error
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 05:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
