Page 16 of 18 FirstFirst ... 6789101112131415161718 LastLast
Results 151 to 160 of 175
Thread: VLC plugin
  1. #151
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by eribs4e View Post
    Hey Lambo,
    Finally got my usb sound card and I can't get it to work with RRVLC. I've set the output device=2 in the config (it's 2 according to dxdiag), but nothing. I've played movies directly from VLC using Directx Sound and the usb sound card and everything works. Also tried from MP Classic and it works from there. RRVLC always plays it on Directx 1 which is my default on board sound.
    Any chance you can have a look at the code? If not, if you're willing to pass it on to me I can have a look at (been a programmer for a long time). If I can't get the sound to work, I'm back at square one for the rear video.
    Thanx.
    I'll have a look as I have never tested that bit. All i did was set the vlc to go to the right card and it allways did it.
  2. #152
    Mar 2006
    Quote Originally Posted by lambosprit View Post
    Thanx lambo.
  3. #153
    lambosprit's Avatar
    Sep 2006
    UK
    Thanx lambo.
    This is a problem. It seems they removed the options bit for security reasons. This is what I use for changing the audio card. It also seems that they have stopped supporting the activex dll so I am doing a rewrite which will hopefully be better and more future proof as it links directly to vlc. It may take a little while to get back to what I had but its the only way now I'm afraid.
  4. #154
    Mar 2006
    Well that sucks....thanx for the effort Lambo. If there's anything I can do to assist, let me know.
    er
  5. #155
    lambosprit's Avatar
    Sep 2006
    UK
    I know its taken a long time but I think I've finally cracked this. The answer is a bit crappy but it works. Will be posting a new version soon.
  6. #156
    Mar 2006
    Awesome. Thanx lambo....been away from the car pc for a while but this was one of the few issues I had left.
  7. #157
    lambosprit's Avatar
    Sep 2006
    UK
    Well I've said it before but now I've def cracked it. Had to completely rewrite it but its ready so who wants to test it? Anynumber of screens all with thier own sound cards (tested with usb)
  8. #158
    Mar 2006
    I'll gladly test it...been using it in its' current form so any improvement is a bonus!!
  9. #159
    lambosprit's Avatar
    Sep 2006
    UK
    Version 3
    Here you go
    two things
    1) must have vlc 1.1.11 installed
    2) Read the readme on how to set up the soundcards. Its a pig and the only way to do it right is the way described.
    Attached Files Attached Files
  10. #160
    lambosprit's Avatar
    Sep 2006
    UK
    anyone got any comments? Does it work?
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 05:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
