Page 10 of 20 FirstFirst 12345678910111213141516171819 ... LastLast
Results 91 to 100 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #91
    Feb 2008
    Hi!
    How do I find radio stations PI number?
  2. #92
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    you can tune the radio and see the sil_rdspi label value
  3. #93
    Nov 2004
    St Louis
    Quote Originally Posted by GizmoQ View Post
    Im trying to install your Silabs version, but cannot complete step 2 above. When I power on the pc it loads ADS driver again. And your TestSilabs.exe crashes.
    Help
    BUMP! Got things working but suffering from static, echo, and noise. Tried to flash with ADS program but then the radio wouldn't work with this plugin. Reloaded Silab flash and noise is back.
    Need step by step instructions for flashing radio with new firmware.
  4. #94
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    heh spider are you able to update this plug for the new rr.exe
    cheers mate
  5. #95
    Feb 2008
    Hi,
    I have the skin working a little.
    Sound is working, tunning in ok
    But the following is not working
    No RDS txt
    Preset menu comes up but memory button doesnt work
    No signal strength indicator working
    Under settings, Set up silabs button not working
    Radio art not working
    Silabs volume skin pops up ok but none of the functions work.
    Any ideas?
  6. #96
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sounds like the plugin is not being activated , make sure the X,TESTSILABS is in your menu.skin and is the last in the list.
    for the art you have to change the art in the art folder to the art you want displayed and change the PI number , the PI number is the station number use that and name the art 50081.jpg .
    as for the others i would say the plugin is not running.
  7. #97
    Feb 2008
    Hi,
    This is my menu.skin
    MEDIACAR Skin
    MEDIACAR menu. Skin
    /, IDL, Seconds
    IDL,300
    X,screenlock
    X,TESTSILABS
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,266,0,276,54,"LOCK_START",
    B10,38,355,135,240,"LOAD;Audio_Player.skin","Audio "
    B11,488,355,135,240,"LOAD;Video_Player.skin","Video"
    B13,178,354,135,240,"LOAD;Radio_Player.skin",@MENU ;Radio_Menu.skin@
    B14,331,355,135,240,"BYVAR;GPSCHOICE;GPS<<GPSDEST< <GPSAUTO<<GPSIGV4",@GPS@
    B15,632,355,135,240,"MENU;exit_menu.skin","Exit Menu"
    B20,693,191,85,91,"LOAD;menu2.skin","Exit Menu"
    B21,24,191,83,90,"LOAD;menu2.skin","Exit Menu"
    B22,116,66,570,284,"RRLOCK",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L30,21,17,135,31,255,255,255,20,"Arial:B","DATE"," CENTER"
    L31,640,17,135,31,255,255,255,20,"Arial:B","EXEC;L OAD;clock.skin||TIME","CENTER"
    END
    And still not working?
  8. #98
    Feb 2008
    I am also getting on exsiting the following errors:
    Project_dll
    Run-time error '91':
    Object variable or With block variable not set
    Then
    Project_dll
    Run-time error '440'
    Automation error
  9. #99
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    try this http://www.microsoft.com/downloads/d...displaylang=en
    and change your radio load button to this "RADIO||sil_start"
  10. #100
    Feb 2008
    Hi,
    Changed to this and now nothing happens when I press the button
    MEDIACAR Skin
    MEDIACAR menu. Skin
    /, IDL, Seconds
    IDL,300
    X,screenlock
    X,TESTSILABS
    B10,40,356,135,240,"CJ_LOAD","Browse By Album Art"
    B13,178,356,135,240,RADIO||sil_start,
    B14,330,354,135,240,"BYVAR;GPSCHOICE;GPS<<GPSDEST< <GPSAUTO<<GPSIGV4",@GPS@
    END
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
