All back working but still the bits dont work?
"" missing
"RADIO||sil_start"
did you copy 1 of the usbradio.dll stereo or quad to the rr folder , needed then reboot
Just did it again, copied from folder, stero one, dropped it in the mainn RR folder. rebooted pc. Still no joy
Some sucsess! I changed the X, TestSilabs to X, TestSilabsdll and the RDS etc is now working.
Only thing not working is the preset menu, memory button
ok i have just made an installer version for this plugin, you have 2 choices in the installer to install the stereo version or the quad version.
Warning this will overwrite your current USBradio.dll, that comes with Road Runner.
Download from here
Mkae sure if not using my skin , to add X,TESTSILABDLL to the menu.skin
Have everything working but the preset menu, it pops up one selected but the memory button isnt doing anything. Also, the silabs setup button doesnt work.
Ok I can wait on the bug fix. I figure a few are going to need it. It works great routing it through the imbedded sound on the mobo. I get static on some chanels and non on others. I am guessing that I may not have enough power to support the usb radio over an extended usb cable(12'). Going to buy a larger output power supply and see what happens. Great job guys........I do graphics if you all need help in that area. I'd post examples, but some may be offended my art.![]()
My new install
D945GCLF2, M350 case,Xenarc 700 tsv,m-4 ATX
Visteon HD radio w/mitches cable, BU-353
2 Punch 150 amps, 1 Kicker ZX 400.1 watt
4 Boston Acoustic Speakers,2 Pioneer 10 subs
i don't know about spider's test skins i did'nt use them, but i think if you press the memory button it changes the function of the preset button to save your current loaded freq. so press memory and then a preset, should display the radio name of the station you have loaded, if no name is displayed open the Testsilabsdll folder and look at the preset.ini see if it is actually saving the station.
Yes extra power is needed if running your silabs through a hub,
How's the installer must be working , now others are now posting i persume,
for others that have not downloaded yet there is no test skin in this installer ,
i can make it an option to have the test skin installed to the skin folder root , but not any percific skin, would this be something to add?
How do you switch preset to rember currently tuned radio station so that it comes on the preset labels?
