Page 12 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 111 to 120 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #111
    Feb 2008
    Doing my own skin and found the following issues with this plugin.
    In my menu skin, I have the X,testsilabdll comand.
    I have registered the regsvr32 testsilabdll.dll.
    But, the "sil_stereo" lable is not working
    The "sil_radioart" lable isnt showing anything. Radio art folder has pictures saved as the pi number.
    There is no way to save the preset as the "memory" button in the test skin preset menu does nothing.
    any chance of the bugs being fixed?
  2. #112
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    hi,
    this is the new versin of my plugin
    inside the zip file were present new testsilabdll.dll and fmod.dll
    only testsilabdll.dll must be registered (regsvr32), the old fmod dll must me replaced with the new fmod dll
    i have fixed many bugs
    the dll is compatible with old and new rr both
    now radioart preset image can be click (is a feature make for skin that haven't space for radio preset buttons, click on image is the same of click on preset button)
    i fix some bugs on the inside setup form and inside the preset section, and now the radio can be resumed automatically in the last frequence heard on rr startup if the radio is the last media you used before rr closing (you can do this using option into inside setup)
    bug known:
    some usb device can be crash the initialization of my usbradio.dll (to be fix)
    Attached Files Attached Files
  3. #113
    Dec 2006
    italy, sardinia
    @the_big_1
    try to use the new version of my dll
    if you find the same bugs i'll try to help you to install the plugin correctly
  4. #114
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    just in time was going to do this skin next cheers Spider
  5. #115
    Dec 2006
    italy, sardinia
    :d
  6. #116
    Feb 2008
    Might have format my pc and start again, now the radio RDS etc does not work. Even the testsilab program does not tune in etc.
  7. #117
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sounds like you need to reg the dll again
  8. #118
    Feb 2008
    I did reg the new dll, has anyone tried the new one?
  9. #119
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    are you useing the latest rr or mitch's ver , cause the new dll is in the new standards
    i think (yet to try this myself) so de-reg the dll move the dll to the plugins folder and re-reg the dll.
    this is all i can think of at the moment, i will try it myself tonight , or spider will come on and help.
    you have only replaced the 2 files , and not removed any others.
  10. #120
    Feb 2008
    Hi,
    Not gone in to the greater detail yet. I just tried using he testlabdll.exe program and that wouldnt show anything either even without running rr so not sure if I have a bigger problem.
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 05:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
