Page 15 of 20 FirstFirst ... 567891011121314151617181920 LastLast
Results 141 to 150 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #141
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    the right procedure is:
    1) tune the radio
    2) wait the pi is displayed
    3) go to the preset popup (if you have it)
    4) click on "sil_memory" buttons
    5) click on preset
    the preset is saved and the radioart will displayed
    this is my preset.skin :
    RoadRunner Skin
    RRScreen presetpopup.
    presetpopup_empty.png,presetpopup_off.png,presetpo pup_on.png,presetpopup_down.png
    B,11,364,62,80,"sil_preset5",
    B,11,276,62,80,"sil_preset4",
    B,10,187,62,80,"sil_preset3",
    B,11,99,62,80,"sil_preset2",
    B,307,459,62,33,"sil_exitaaf",
    B,310,364,62,80,"sil_preset0",
    B,310,277,62,80,"sil_preset9",
    B,312,187,62,80,"sil_preset8",
    B,311,98,62,80,"sil_preset7",
    B,310,11,62,77,"sil_preset6",
    B,11,10,62,77,"sil_preset1",
    B,382,452,210,40,"EXIT",
    L,390,388,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name0",
    L,389,298,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name9",
    L,388,208,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name8",
    L,388,120,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name7",
    L,388,30,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name6",
    L,88,387,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name5",
    L,89,299,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name4",
    L,90,209,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name3",
    L,89,120,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name2",
    L,90,30,130,36,255,255,255,24,"Ericsson GA628","sil_preset_name1",
    I,525,373,61,67,"sil_preset_radioart0"
    I,523,283,61,67,"sil_preset_radioart9"
    I,522,195,61,67,"sil_preset_radioart8"
    I,522,107,61,67,"sil_preset_radioart7"
    I,523,15,61,67,"sil_preset_radioart6"
    I,223,373,61,67,"sil_preset_radioart5"
    I,224,283,61,67,"sil_preset_radioart4"
    I,223,197,61,67,"sil_preset_radioart3"
    I,223,105,61,67,"sil_preset_radioart2"
    I,224,17,61,67,"sil_preset_radioart1"
    I,82,454,211,38,"sil_memory"
    END
  2. #142
    Dec 2006
    italy, sardinia
    ops...
    sometimes my firefox send a "double post"
  3. #143
    Feb 2008
    Hi,
    I dont have a pop up, this is the radio skin I use
    /, F, x, y, w, h, Filename
    F,637,5,160,45,"Digit.swf"
    /, J, x, y, w, h
    J,537,227,125,84
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,169,121,92,91,"FMPRESET;PRESET1||SETVARBYCODE; FMP01;FREQUENCE||SAVETOSKIN;FMP01;$FMP01$||SETLABE L;!PRESET;Fm1",""
    B02,264,121,93,90,"FMPRESET;PRESET2||SETVARBYCODE; FMP02;FREQUENCE||SAVETOSKIN;FMP02;$FMP02$||SETLABE L;!PRESET;Fm2",
    B03,362,122,96,89,"FMPRESET;PRESET3||SETVARBYCODE; FMP03;FREQUENCE||SAVETOSKIN;FMP03;$FMP03$||SETLABE L;!PRESET;Fm3",
    B04,463,123,91,88,"FMPRESET;PRESET4||SETVARBYCODE; FMP04;FREQUENCE||SAVETOSKIN;FMP04;$FMP04$||SETLABE L;!PRESET;Fm4",
    B05,551,122,98,88,"FMPRESET;PRESET5||SETVARBYCODE; FMP05;FREQUENCE||SAVETOSKIN;FMP05;$FMP05$||SETLABE L;!PRESET;Fm5",
    B09,218,504,112,84,"FREQ-||SETLABEL;!PRESET;- - -",
    B10,469,505,107,81,"FREQ+||SETLABEL;!PRESET;- - -",
    B11,3,507,97,81,"VOL-",@MASTERMUTE@
    B13,100,507,100,81,"VOL+","Volume+"
    B13,279,409,88,32,"Mastermute","Volume+"
    B13,421,409,88,32,"Mastermute","Volume+"
    B14,699,508,97,78,"EXIT","Exit"
    B14,598,508,100,78,"LOAD;Radio_Menu_Function.skin" ,
    B16,329,498,140,94,"SETLABEL;!PRESET;- - -||TUNE||SAY;Enter Frequency","Tune"
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,555,180,46,29,"sil_preset_radioart5"
    I01,460,180,48,29,"sil_preset_radioart4"
    I01,360,180,46,29,"sil_preset_radioart3"
    I01,264,180,50,29,"sil_preset_radioart2"
    I01,171,181,43,29,"sil_preset_radioart1"
    I01,540,230,119,77,"sil_radioart"
    I01,366,387,59,21,"MASTERMUTE:b"
    I,83,237,66,75,"HDACTIVE"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,250,220,271,92,255,255,255,48,"LCD Display Grid","FREQUENCE","CENTER"
    L04,288,12,206,36,255,255,255,24,"BN Deep Blue:B","sil_RDSPTYString","scroll-center"
    L04,53,12,211,36,255,255,255,24,"BN Deep Blue:B","sil_rdsps","scroll-center"
    L04,142,334,484,28,255,255,255,18,"BN Deep Blue:B","sil_RDSText","SCROLL-LEFT"
    L20,79,257,160,45,255,255,255,24,"LCD Display Grid","BYIND;HDACTIVE;=ANALOG<<=HD||HDSUB" ,"right"
    L,0,0,0,0,0,0,0,18,"Arial","CUSTOMFREEFONE", ""
    L,366,414,58,20,255,255,255,16,"Futured","VOLUME", "CENTER"
    L06,555,154,90,20,255,255,255,16,"Futured","=$FMP0 5$","CENTER"
    L07,459,154,90,20,255,255,255,16,"Futured","=$FMP0 4$","CENTER"
    L08,363,154,90,20,255,255,255,16,"Futured","=$FMP0 3$","CENTER"
    L09,266,155,90,20,255,255,255,16,"Futured","=$FMP0 2$","CENTER"
    L10,168,156,90,20,255,255,255,16,"Futured","=$FMP0 1$","CENTER"
    L,0,0,0,0,0,0,0,8,"Arial","FERQUENCE",
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,0,0,0,0,253,253,247,000,000,000,0,255,255,153, 141,119,44,237,33,false,18,"Futured"
    /, Y, Back Slider file path
    Y01,"slider_signal\SLIDER_*.gif"
    I,532,410,50,34,"sil_taswindicators"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    END
  4. #144
    Dec 2006
    italy, sardinia
    you must modify you skin using my commands and labels
    in my dll the preset name was saved using the "radio name" from the rds data
    i don't edit or set its name,
    for display it in my preset i'm only tune the radio and save it as preset
    entire procedure is automatic
    if is necessary i can modify its name manually editing the preset.ini
  5. #145
    Dec 2006
    italy, sardinia
    p.s. you can't have a preset.skin and use all my commands/indicators/labels into the radio skin or in any .skin of your skin
  6. #146
    Feb 2008
    Great stuff!
    New to this.
    What should B01,169,121,92,91,"FMPRESET;PRESET1||SETVARBYCODE; FMP01;FREQUENCE||SAVETOSKIN;FMP01;$FMP01$||SETLABE L;!PRESET;Fm1",""
    be changed to for it to be good?
  7. #147
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sil_preset_name0 = Label code
    sil_preset4 = Button code
    sil_memory = button code , to change the function of the sil_presetX code for saving to loading preset
  8. #148
    Feb 2008
    lol so new to this, what do I need to change on the above?
  9. #149
    Dec 2006
    italy, sardinia
    B01,169,121,92,91,"sil_preset5",
    L06,555,154,90,20,255,255,255,16,"Futured","sil_pr eset_name5","CENTER"
    you may add a button like this:
    it's for enable the saving opton of the preset
  10. #150
    Feb 2008
    Thanks for all your help!
    Is there anywhere I can get a copy of your skin for the radio with the preset skin too so I can look at it and try addapt parts to make mine work better and more like yours?
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
