Page 16 of 20 FirstFirst ... 67891011121314151617181920 LastLast
Results 151 to 160 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #151
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    you can download my entire skin at:
    http://mio.discoremoto.alice.it/spidermunz
  2. #152
    Dec 2006
    italy, sardinia
    this file is not a complete skin!!!
    it is only radio part skin, you can use it coping it into your (complete) skin
    it's only for test, only to learn how can modify your prefered skin
    you can see the radio skin preview at first post
    Attached Files Attached Files
  3. #153
    Feb 2008
    Cheers!
    I will have a play over the weekend and let you know how I get on.
  4. #154
    Feb 2008
    Hi,
    Can you tell me how you save the preset in your skin.
    I tried tunning to the station, clicking preset pop up. clicking memory, then preset 1 but nothing happens.
  5. #155
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you must have the name and pi number displaying 1st in main skin before you can save a preset, press memory once then a number saves , then memory returns to load state,
    so you can only do 1 memory at a time like a normal headunit memory.
  6. #156
    Feb 2008
    Hi,
    I tried that, I was tuned in, radio art showing etc. I clicked memory then the preset number. The radio went to the normal player skin but the preset isnt saved?
  7. #157
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    how do you have the files set in rr root,
    the preset.ini, should be in the testsilabsconfig folder in rr root with testsilabs.ini
    just to try as i have a load problem last try, open the testsilabs folder and manually add a preset , name,pi number , freq.
    and see if that shows,
    rr must be restarted
  8. #158
    Feb 2008
    Hi,
    Yes it works if I do it that way and the files amd folders are in the correct place.
    I have a button with "sil_memory","prest" and then buttons "sil_preset1" Sil_preset2" etc.
    Once I click memory, then the preset button, the radio skin changes and the radio display shows "0" and anologe?
    Also, is there any way of showing what the preset number is actualy in use, i.e a labe that would show "1" when preset 1 is pressed etc?
  9. #159
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    are you useing spiders test skin for radio
    i'm also getting so wierd behaivor on preset,
    load mainly on press it goes to main menu scr , but i need to play some more
  10. #160
    Feb 2008
    No. I have modified a different one and coppied a lot of the comands, lables etc over.
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 05:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
