Page 17 of 20 FirstFirst ... 7891011121314151617181920 LastLast
Results 161 to 170 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #161
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mmmm will take a further look tonight after work, if you are modifing a skin ,
    make sure your launch button is silabs||radio
    you probably have this already , but just to make sure,
    i can't remember by byind code to show the function of the memory button to say load or save.
    but by default it should be load then on press save, but i will play tonight
  2. #162
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    stick this where your presets are this will show you what mode the sil_memory is in
    L06,413,298,165,59,2555,255,255,18,"Arial","BYIND; sil_memory;=Load <<=Save","CENTER"
    you will have to edit the postion of the label for your needs
  3. #163
    Feb 2008
    Cheers,
    I know it could be a simple miss by me, what is the full silabs launch code that should be in the skin. I know it begins with an "X". I had it I am sure but can not find it which skin I put it in lol
  4. #164
    Feb 2008
    Is there any way of having it show the preset in one place only. I want a to place a lable on a different skin that show which current preset is on, rather than haveing all four there and showing which one is active.
  5. #165
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    in menu.skin or plugins.txt which ever you use
    X,TESTSILABDLL
    lauch code on button silabs||radio
    i look into it presets
  6. #166
    Feb 2008
    Hi,
    I found the launch code, I did have it.
    Please do look at the preset saving issue and the single preset on identification.
    thanks a million!
  7. #167
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    @big you have pm
  8. #168
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    right before i try this need to make sure i have what you want correct.
    you have your presets for load/save in another skin away from main radio skin.
    and you want a indicator of some form in the main radio skin to identify that the preset you have activated in the main radio skin.
    so do you want just the station name showing,or all preset info name/freq/pi number or 1 - 6 lights , that light up when the corrasponding preset is active,
  9. #169
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    spider load/save preset works here , but on load of preset , it dose load the station but it changes the screen from radio to main menu , it dose not stay on radio screen
    otherwise so far so good.
    once i have it all good i will remake the installer for you.
  10. #170
    Feb 2008
    E mailed.
    The preset I just want the number, I.E 1 to 4 to be on as a digit in one place, Like a car radio does. You should get the idea from the skin sent.
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
