Page 19 of 20 FirstFirst ... 91011121314151617181920 LastLast
Results 181 to 190 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #181
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    i can't compile new dll (ride runner format)
    vb6 give me this error all the time i try to compile
    "can't find project or library"
    someone can help me?
  2. #182
    Low Bitrate JohnnySierra's Avatar
    Mar 2009
    Italy
    Copy Riderunner.exe into the project folder of your code.
  3. #183
    Dec 2006
    italy, sardinia
    i haven't finished the silabs plugin for riderunner
    try this solutions
    1) download my last packs for silabs
    2) open the riderunner main folder
    3) delete the usbradio.dll of riderunner
    4) copy my usbradio.dll in riderunner folder
    5) copy all dll and folder of my packs into riderunner main folder
    6) open dos windows
    7) in the dos windows go to the mainfolder of riderunner
    8) write "regsvr32 testsilabdll.dll" we must appears a confirm windows
    9) write in your skin x,testsilabdll
    10) run riderunner and pray
    in my sistem it works fine, like in the old road runner
    i have some little problems with the conversion of the old to the new format of riderunner plugin
    i must win riderunner and write a good plugin
  4. #184
    Jun 2005
    Dresden, Germany
    Where can I download the new pack? The first posting has no new edit.
  5. #185
    Dec 2006
    italy, sardinia
    i have not make any new plugin
    the plugin in the pack of first post can be used in road-runner ride-runner both
    if you use the plug in riderunner you must to use in the same way of road runner
    you must put in the menu.skim this tring x,testsilabdll
    and copy the dll and its folder in the main folder of riderunner (same way of road runner)
    i working for make a new plugin riderunner compatible (native riderunner plugin)
    but for now i have a problem, riderunner don't want load the usbradio (rideruner plugin)
    this is the reason because we must use the plugin in riderunner as road-runner plugin
  6. #186
    Apr 2009
    Hi, I use your great plugin - thanx for work.
    Some problems:
    1.
    Run it with RideRunner and RoadRunner and see the same result - no sound (it work with USBRadio.dll from this http://silabsradiodll.googlecode.com...-1.7-beta5.zip WITH Filter.grf only) on vista, on winxp.
    I used Carwings-V2 skin.
    2.
    If i use DigitalFX 4.0 skin there was no sound. What problem with this skin?
    3.
    And no indicators except frequency on screen.
    4.
    Cant insert x,testsilabdll - write error in usbradio.dll
    Thanx.
  7. #187
    Dec 2006
    italy, sardinia
    have you download the visual studio runtimes and copy the fmon.dll in road/ride runner main folder?
    have you copy my usbradio in road/ride runner main folder? (you must delete the usbradio.dll of guoino and put mine in the folder)
    have you registered my testsilabdll.dll using regsvr32 in dos windows?
    try all this things, and give me more details
    (it can be usefull to fix all bugs)
  8. #188
    Apr 2009
    Quote Originally Posted by spidermunz View Post
    1.yes, visual studio installed, fmodex.dll in rr root
    2.yes, try stereo or quadro
    3.yes, registered in windows (command line of total commander) & try in dos mode.
    today replace usbradio.dll from your pack to usbradio.dll from USBRadio-1.7-beta5.zip again and it sound
    insert x,testsilabdll in any place of main.skin?
    Can you try DigitalFX 4.0 skin?
    What details do you need also? i ready.
  9. #189
    MySQL Error
    Oct 2004
    FYI x,pluginname is depreciated
    also, to make a new plugin, the vb project needs to reference RideRunner.exe
    (so it can use its COM interface)
    just fix the reference!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  10. #190
    Nov 2004
    St Louis
    Quote Originally Posted by mitchjs View Post
    Unless you use multiple skin with differing plugin requirements and don't want duplication in the skin directories.
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
