i'll post a provvisory test screen with new commands to test it
some features like automatic af is disable because i need to coplete to develope it
the automatic af sil working on 80%, the oter 20% are the sub routine needed to get the af list and menù to set the tollerance porwer segnal of radio needet to start the automatic af, and swich command to set it and some minour features, its simple for me to realize them
semi/automatic af is working fine
in this moment i use the usbradio 0.6 to get the sf list for all station, then i use all the list af station in the usbradio 1.0
this because the usbradio 1.0 get me a list of PI code station, not the alternate frequence of radio tuned up,
i improve the function adding all the time you receive an af list where all the new frequence are not present in the older list
the max number of af fist is 25 by rds standard
the frequence non present is named "0", in the scan of automatic af the frequence we are starting for is not processed, same for the prequence named "0"
if the alternate frequence is tuned ok and pi of radio station is ok its percentuals of right tune is refreshed with a new number and the list of frequence is sort using the percentuals to sort it
the first frequence that the automatic af try is the most £right£ frequence if was tuned right, all the time the automatic af fail the tune its try to tune the frequence to the next in the list that have minour percentuals of right connections
this requaire less time to change from the initial frequence to the new right frequence
all the feature are simple to realize, but the dll take most the time i need for my occupation/study (i'm a lawyer) but i work on it in all my free time
Whereas i work to 2 weeks, in my free time, I believe that it has obtained good results
the automatic af function occupied most of the time and tried to optimize the first version to this better
more time i use this function, less is the time needed to change into the right frequence!
all using one silab
but i know i make better adding other funziotn inside the dll
(sorry for my english, i post from italy and i doesn't write in english from 12 hears ago)
