Page 5 of 20 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #41
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok
    radio art
    the folder named "radioart" is in my RR folder "root" jpg inside it with pi number 50086.jpg
    as for rds i get it somtimes so i'm putting that down to my arial.
    as for mute did the sdk example and send command nothing
    standard rr cmd mastermute works but that mutes the master vol.
    also todat i got an echo on the radio broadcast, then it disappeared then it was back again. i'm not a radio tech, so half the stuff in this plugin, i'm not sure what it dose lol...
    is the radio art path hardcoded to c:\programmi\road runner\radioart, if so might be the problem with "programmi" when we use "program files" here that might be the problem.
    EDIT further test the echo i have stops when i use mute and is back on unmute, so i'm getting 2 audio radio, 1 which is muted by your mute cmds
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #42
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mute now working had a linein80 dll in my winamp plugins folder deleted that and the echo now gone and mute now works.
  3. #43
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    Quote Originally Posted by carputer1 View Post
    ok
    radio art
    i forgot two thinghs
    1)the direct sound dll don't need line in winamp
    if you use winamp linein on in the rrconfig uncheck it! or winamp generate echo of radio streaming
    2) update the firmware of the silabs using adsconfig, you can find the last version here:
    http://code.google.com/p/silabsradiodll/downloads/list
    use the ADS Standard.dec or ADS NoiseMod Secondary.dec
    after the update, uninstall from the system resource the "usb multifunciotnal resource" (i don't know how is named in english) you can view the right to remove loking its detail,
    it is named "ADS InstantFM Music"
    after remove the silabs forrm the usb port, power off the system (not reset, power off)
    power on the pc, and put the silabs into an usb port
    now the silabs work again and you don't have problem inside the plugin
  4. #44
    Dec 2006
    italy, sardinia
    this is a radio player skin-test for my extension
    the rar file contain radioart of italian radio
    you can rename it and use for test
    Attached Files Attached Files
  5. #45
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well update done, skin cmds checked all fine ,everything apart from the art is working,
    which looks to be a path issue.
  6. #46
    Dec 2006
    italy, sardinia
    it is strange because is the same type of procedure that i use for load dll setting ini file
    i look on my source if there is a bug inside of it
    tank you for testing/debugging my dll
  7. #47
    Dec 2006
    italy, sardinia
    for now, in radioart folder, use ONLY a .jpg file
  8. #48
    Dec 2006
    italy, sardinia
    well i thought i had everything working, just installed the last updates, but i.m having a few problems.
    unable to mute/unmute with mutesilabs /unmutesilabs
    getting no radioart showing, but that might the way i'm labeling it, what am i suppose to label the jpg to.
    rdstext is gone ,may be due to the blue wire arial but had it once before.
    cheers
    i found the rds txt bug
    the right command is "sil_RDSText" not "sil_rdstext"
    this bugs is present also in the test skin i posted tomorrow
  9. #49
    Dec 2006
    italy, sardinia
    I forgot one things!
    my extension plugin is capable to receive some "codes" from other application
    you can use in your source code:COMSend "Silabs Test", "11"
    or from rr "SENDMSG;Silabs Test;11"
    the codes are:
    11 mute silabs
    12 unmute silabs
    13 change volume to x% (from 0% to 100% of radio volume)
    14 change volume from x% to setting before 13 code
    x value is in testsilabsdll.ini on the DRIVEMON voice:
    [State Of Setup]
    news_switch=False
    ti_switch=False
    last frequence=90,30
    MinStrengthRadio=25
    frontsx=100
    frontdx=100
    rear_sx=72
    rear_dx=72
    drivemon=25
    muteafpopup=False
    i make this feature for phone programs or gps software (drivemon is a program that decrease music volume when sygic drive (gps software) is "talking") (drivemon was made @SkyNet )
    if you change value of muteafpopup to True, inside the automatic seek of alternate frequence popup the seek start with siabs muted, and at the end of the complete seek the silabs is unmuted (or when you exit from the popup)
  10. #50
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    WOW! I'm dusting-off my Silabs as we speak!
    @ SpiderMunz - is the radio screen in your spider-skin good for this or does the new commands have to be incorporated.
    @ Carputer1 - Spider put-out a boat-load of files so far; can you spoonfeed me which files to download and how to go about getting everything to work..plz.
    My soldering gun is hot now so let me go hack this baby..
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
