on first test EON works fine in my test-form
excellent
@Tree if you need any help shout.
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
ok , i finished the test for EON (thanks skynet and 307SW_NLD)
i think in next radio skin it is possible to integrate very large number of label and indicators
and some of those can be put into some popup, if you haven't 10" display
this is the test form i use in the test
you can see the EON in action
p.s. RAI is the national italian radio and television, radio1 - radio2 - radio3 is its radio group
in future version i think to integrate:
1) add to "pi".ini file new alternate frequence founded
2) add preset using rds name and image indicator for the radio station
3) seek of radio channel based by pty programs
4) change radio station on EON TA on and return to old radio station on EON TA off
5) label for eon radio ps and eon tpytext radio programs
6) change radio touching name on eon ps of readio need to change
7) after exit from automatic/manual af seek change TI state to on after tot minute (if TI was on)
8) make setup.exe to setup the dll and can start it into rr
9) blink AF indicator on automatic/manual af seek
10) make "user defined" the use of AF popup or new popup simple changing a value in .ini setup of dll
11) pdf manual of the dll and its function supported description
more addition can be possible (i'm evaluating some) , it is a list of feature "must" to do
any your idea for improve the plugin can be a good idea, you only tell me and i make the possible to do
my idea is make the plugin better flexible or configurable by the user
thats handy a help file and installer. keep those updates comming
ok, i can make the pdf/word file, my friend can traduce it in english and you can make the help file starting from it
but first i need to finish the plugin, after we can do the help file and installer
if i don't integrate some feature we didn't include it inside the help file![]()
