Page 8 of 20 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #71
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Fantastic Spider - Thanks. Let's go testing!
  2. #72
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    i fix some bugs reguarding eon and preset and skin test
    new version (2.0.1) is on first post
    if you use sygic drive gps, now silabs decrease its volume when drive is talking, for this features need to install drivemon software by skynet, if you are intrested i can upload it
  3. #73
    Constant Bitrate almera's Avatar
    Aug 2004
    nice plugin, thanks for sharing, I would like to know how drivemon feature works, I'm using Sygic drive with drivemon, works succesfully with winamp, but nothing happens with your plugin when sygic drive talks
  4. #74
    Dec 2006
    italy, sardinia
    have you the drivemon version of last day?
    only last bersion of drivemon support my plugin
    try this:
    drivemon 7.50.514.rar
    you must go inthe setup of my dll and set the drivemon volume
    drivemon is written by skynet, the same author of usbradio.dll i use
    we test drivemon and we know it works
    drivemon send me one command to start mute and one command to resume from mute
    p.s. later i make support for freephone
  5. #75
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    here we go 1st draft of the cammands and descriptions in English
    Attached Files Attached Files
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  6. #76
    Dec 2006
    italy, sardinia
    thank you carputer1 for your help
    i will add your file in next version
    (i may fix some preset bug)
  7. #77
    Dec 2006
    italy, sardinia
    TRANSLATION OF BLACK TEXT
    Installation:
    This dll and this plugin enables the functionality of the radio usb silabs taking it to the level of an autoradio rds.
    The dll Usbradio.dll created using fmod sound engine. You will find 2 UsbRadio.dll 1 for stereo version , and the other for quadraphonic version.
    Copy what is suitable for your system into your roadrunner Root.
    Copy the contents of the Road Runner folder to road runner Root.
    Follow the command regsvr32 testsilabdll.dll
    In the case of a previous installation, first de-register the dll with the command regsvr32 testsilabdll.dll / u then you may proceed with the New installation.
    In the radioart folder insert the graphics that shows the logo of the radio station, the name of .jpg must be the name of the pi address, (this the pi number of the station (the ‘p’ is the id code of the radio and is expressed in decimal code).
    The configuration file of the plugin is in the testsilabdllconfig folder, also the alternative preset frequencies of each radio (station?)
    Function:
    The testsilabdll attaches a set of commands for starting and visualising the rds better to the pre-existing commands of Roadrunner.
    The dll furnishes a fast comprehensive rds support of all the present rds information.
    Function TA:
    If function Tl is activated Roadrunner will switch itself automatically to the radio screen in the case of a traffic bulletin, in the case of any transmitted message issuing on another radio (station) belonging to the EON group the radio will automatically tune in to that.
    Function NEWS:
    If the NEWS function is activated, Roadrunner will automatically switch to radio screen in case of news-type radio, in this case any message transmitted on another radio station belonging to the EON group the radio will tune automatically on that one.
    Function Tl:
    In the case of a radio station using an alternative frequency, you can use the af function in automatic or in manual (in manual mode, the command is sil_maf), this allows radio frequency to be changed searching for a better signal for the radio station listened to.
    Function Memory:
    If you should wish to memorise a preset key, the memory key must be activated, then press the preset key, the current radio station will be memorised on this.
    Function Popup:
    Your choice for skinners
    2 Popups can be integrated in the skin, one popup preset (doesn’t matter what the name is) and one search af popup (silabsaf.skin).
    By use the command sil_setup you can access the dll setup. In this you can check if the popup af is active or not, if the preset popup is active or not, and if wished, that the silabs are changed during the search af.
    In the af popup you can put in position the sil_exitaf key through which it is possible to exit from the cycle returning to the original frequency, each function from the outside for the popup can be activated from the manual search key sil_maf.
    In the pre-set popup it is possible to insert pre-set selection keys, the pre-set name label, the pre-set indicators that visualise the miniature pre-set radio, but I recommend inserting also the sil_memory key to enable access to the saving of a pre-set.
    Function Set-up:
    The command sil_setup accesses a form of setup, through which you can access and modify the various values of the plugin configuration.
    You can make the 4 audio channels from the setup form that through the commands of the skin.
    When using the stereo version of the dll usbradio, 4 channels will be ignored.
    Function EON:
    I advise you to superimpose the name label of the radio station eon with it’s indicator, in this way it is possible, clicking on the name, to tune the radio to the eon station desired.
    IMPORTANT:
    You must insert the following command: “CLOSEWINDOW:SDKSilabs | | QUIT” into the ‘quit’ of road runner.
  8. #78
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    for those who have noticed that their custom_inds have stopped working i have just this minute recieved an update which dose solve this issue, further testing when home from work tonight.
  9. #79
    Dec 2006
    italy, sardinia
    tonight i will put in download the last version (now in italy are 13:00)
    i rewrite the preset function and i write support for freephone
    i post tonight because i will make first some test and i wait feedback by by betatester (carputer1 and some friends in italy)
    i try to make the better and flexible plugin for silabs
    i will make all the function that silabs can use
    any comments/critics/idea are appreciate
    all is usefull to make better support for it
  10. #80
    Dec 2006
    italy, sardinia
    New version fixed of dll in first post
    preset and drivemon (sygic gps drive) support now is better
    i olso add freephone support
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
