Page 9 of 20 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
  1. #81
    Apr 2008
    can anyone explain to me why no matter what skin i use in rr why my silabs radio picks up static,if i go to the radio tab whatever preset i am on i have to select a different freqency ,then go back to the one i want to get audio ,it also doesnt matter what usbradio.dll i use i just cant switch to radio and it work i hae to switch freqency back and forth, also i get skipping in the audio
  2. #82
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    how have you set silabs up in your rrconfig, and are you using the linein plugin(if so remove it) in config you should selected silabs (7) and at the top tune to all Freq,
    leave everything else, if problems still persist open rrconfig and set the card reset.
    also did you register the testsilabs.dll
    and did you ever have this working before.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #83
    Nov 2004
    St Louis
    Quote Originally Posted by spidermunz View Post
    i forgot two thinghs
    1)the direct sound dll don't need line in winamp
    if you use winamp linein on in the rrconfig uncheck it! or winamp generate echo of radio streaming
    2) update the firmware of the silabs using adsconfig, you can find the last version here:
    http://code.google.com/p/silabsradiodll/downloads/list
    use the ADS Standard.dec or ADS NoiseMod Secondary.dec
    after the update, uninstall from the system resource the "usb multifunciotnal resource" (i don't know how is named in english) you can view the right to remove loking its detail,
    it is named "ADS InstantFM Music"
    after remove the silabs forrm the usb port, power off the system (not reset, power off)
    power on the pc, and put the silabs into an usb port
    now the silabs work again and you don't have problem inside the plugin
    Im trying to install your Silabs version, but cannot complete step 2 above. When I power on the pc it loads ADS driver again. And your TestSilabs.exe crashes.
    Help
  4. #84
    Low Bitrate SoloconDeus's Avatar
    Sep 2007
    it works as longs as I am using the on board sound though the skin. I can use the ADS config Beta 2 exe and I will get sound. If I go to using my Turtle beach USB sound card it won't work through the skin. It will though the EXE beta 2. The Turtle Beach USB sound card is the one in my car.
    Any one have any ideas, it's a great skin, and great workmanship on the DLL. I am using the latest RR.exe, the silabls USB FM RD radio and the stick.
    My new install
    D945GCLF2, M350 case,Xenarc 700 tsv,m-4 ATX
    Visteon HD radio w/mitches cable, BU-353
    2 Punch 150 amps, 1 Kicker ZX 400.1 watt
    4 Boston Acoustic Speakers,2 Pioneer 10 subs
  5. #85
    Feb 2008
    Hi,
    I would like to use this plugin with a skin I have just down loaded.
    Download all the files, registered the dll etc.
    What do I need to add to the skin menu to get the plugin to start up etc?
    Below is the skin txt.
    MEDIACAR Skin
    MEDIACAR "radioplayer" Skin
    radio_player_off.png,radio_player_off.png,radio_pl ayer_on.png,radio_player_on.png
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B07,12,452,86,117,"MENU;Volume.skin",@MUTE@
    B08,166,65,150,35,"SETVARBYCODE;HDCHAN;HDSUB||SETV ARBYCODE;HDCOUNT;HDSUBCOUNT||EVAL;HDCHAN;1+(($HDCH AN$)%($HDCOUNT$-1))||HDSUB;$HDCHAN$","HD Sub's"
    B08,5,65,150,35,"FUNCTION",""
    B09,342,442,116,147,"TUNE","Tune"
    B10,647,65,150,35,"PRESET","Preset"
    B11,222,442,116,147,"FREQ-","Frequence -"
    B12,326,65,150,35,"SCAN","Scan Mode"
    B13,486,65,150,35,"SURF","Surf"
    B14,463,442,117,148,"FREQ+","Frequence +"
    B13,702,452,86,117,"MAIN",@MYEXIT@
    B15,20,117,70,67,"PGUP","Page Up"
    B17,20,287,70,67,"PGDOWN","Page Down"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,416,208,277,82,255,255,255,60,"Arial","FREQUEN CE","CENTER"
    L02,200,17,399,31,255,255,255,20,"Arial","RDSNAME" ,"CENTER"
    L03,25,379,751,20,255,255,255,12,"Tahoma","BYIND;H DACTIVE;RADIONUMBER||= - ||RADIONAME<<HDARTIST1||= - ||HDTITLE1","SCROLL-CENTER"
    L03,416,126,349,19,255,255,128,12,"Tahoma:B","BYIN D;HDACTIVE;=ANALOG<<=HD||HDSUB","CENTER"
    L04,25,409,751,20,255,255,255,12,"Tahoma","BYIND;H DACTIVE;=No HD Sub-Channel<<HDARTIST2||= - ||HDTITLE2","SCROLL-CENTER"
    L30,21,17,135,31,255,255,255,20,"Arial:B","DATE"," CENTER"
    L30,697,256,66,34,255,255,128,18,"Tahoma:B","BYIND ;FMAM;=kHz<<=MHz","CENTER"
    L30,416,169,64,34,255,255,128,18,"Tahoma:B","BYIND ;FMAM;=AM<<=FM","CENTER"
    L31,640,17,135,31,255,255,255,20,"Arial:B","EXEC;L OAD;clock.skin||TIME","CENTER"
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,549,305,78,28,"STEREO"
    I02,417,305,70,27,"LOCAL"
    I03,698,306,63,27,"SCAN"
    I04,710,161,53,42,"HDACTIVE"
    INC,pl.ils
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,94,127,300,223,255,255,255,255,255,255,255,255 ,255,0,0,0,255,255,0,true,16,"Calibri"
    /, Y, Back Slider file path
    Y01,"sat_signal\slider_*.gif"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,609,161,95,29,484,184,110,57,H,01," ",57,"HDSIGNAL",""
    END
  6. #86
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this plugin use a whole lot of different cmds so vals skin file will not work with this plugin , in the download should of been instructions and test skin try it
  7. #87
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    sorry for delayed reply
    some problem can be find in system that have usb sound card
    usbradio.dll have a bug in the init sub of the sound (fmod sound init)
    i will talk to skynet for fix this bug
    @the big 1: to start the plugin must add to the main.skin the follow line:
    x, testsilabdll
  8. #88
    Feb 2008
    Hi,
    Thats the bit I couldnt understand, how to get the test skin to operate.
  9. #89
    Feb 2008
    Hi,
    Sorry to be a pain!
    I got the radio bit working ok but I dont understand how the "PI" is created for the radio station. I have downloaded some radio art for some radio stations and want to save as the correct file name so they show up on the presets.
  10. #90
    Dec 2006
    italy, sardinia
    the "pi" number is the radio station number code identificator
    all radio has its pi, i use the radio number to the radioart
    to make it automatically i used the "pi" number received by rds
    it also used to make automatically the file of the alternate frequencies list ( "pi".ini ) of the radio station, it's used for the automatic frequence change on radio signal strength low
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
