Page 1 of 20 1234567891011 ... LastLast
Results 1 to 10 of 194
Thread: spider plugin, new labels/indicators/function/commands for silabs
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    edit 7/22/2008
    i make some improvements on preset function and drivemon support
    i have upload new version of dll
    edit 7/14/2008
    this is the final version of my plugin for roadrunner and silabs
    it have many function
    1) directsound stereo or quadriphonic
    2) fast rds data
    3) full rds support
    4) full eon support
    5) smart automatic/manual seek for alternate frequencies
    6) smart preset, your radio station is found anywhere, if is in different frequence dll tune it
    7) TA function, rr is switched to radio if TA is transmitted on tuned frequence or EON 8) radio station
    9) NEWS function, rr is switched to radio if NEWS is transmitted on tuned frequence or 10) EON radio station
    11) radioart for tuned station and preset station
    12) setup for dll
    13) alternate frequencies list is update if new frequence is found
    14) eon radio station can be tuned by simple click on the screen
    15) you can setup your quadriphonic/stereo system using different volume for each channell
    16) popup for preset and af seek supported
    17) separate volume for channel-silab master volume
    18) differentvolume for TA Function
    19) different volume for NEWS function
    sorry if txt command is in italian, my friends carputer1 translate it soon
    in the file i stored a test skin for radio
    thr dll id optimized for single tuners, but work very fast
    smart af seek after 4-5 times you use, it tune the radio quickly
    this dll is an ideal solution for people travelling frequently on the same zones and own only one FM Radio
    remember to add x,testsilabdll inside the main.skin of your skin
    i add in the zip file the last beta version of rr and usbradio.dll (5/27/2008)
    this file must be downloaded and installed for 2.0 version of the dll:
    http://www.microsoft.com/downloads/d...displaylang=en
    Attached Files Attached Files
    Dec 2006
    italy, sardinia
    TRANSLATION OF BLACK TEXT
    Installation:
    This dll and this plugin enables the functionality of the radio usb silabs taking it to the level of an autoradio rds.
    The dll Usbradio.dll created by SkyNet . You will find 2 UsbRadio.dll 1 for stereo version , and the other for quadraphonic version.
    Copy what is suitable for your system into your roadrunner Root.
    Copy the contents of the Road Runner folder to road runner Root.
    Follow the command regsvr32 testsilabdll.dll
    In the case of a previous installation, first de-register the dll with the command regsvr32 testsilabdll.dll / u then you may proceed with the New installation.
    In the radioart folder insert the graphics that shows the logo of the radio station, the name of .jpg must be the name of the pi address, (this the pi number of the station (the ‘p’ is the id code of the radio and is expressed in decimal code).
    The configuration file of the plugin is in the testsilabdllconfig folder, also the alternative preset frequencies of each radio (station?)
    Function:
    The testsilabdll attaches a set of commands for starting and visualising the rds better to the pre-existing commands of Roadrunner.
    The dll furnishes a fast comprehensive rds support of all the present rds information.
    Function TA:
    If function Tl is activated Roadrunner will switch itself automatically to the radio screen in the case of a traffic bulletin, in the case of any transmitted message issuing on another radio (station) belonging to the EON group the radio will automatically tune in to that.
    Function NEWS:
    If the NEWS function is activated, Roadrunner will automatically switch to radio screen in case of news-type radio, in this case any message transmitted on another radio station belonging to the EON group the radio will tune automatically on that one.
    Function Tl:
    In the case of a radio station using an alternative frequency, you can use the af function in automatic or in manual (in manual mode, the command is sil_maf), this allows radio frequency to be changed searching for a better signal for the radio station listened to.
    Function Memory:
    If you should wish to memorise a preset key, the memory key must be activated, then press the preset key, the current radio station will be memorised on this.
    Function Popup:
    Your choice for skinners
    2 Popups can be integrated in the skin, one popup preset (doesn’t matter what the name is) and one search af popup (silabsaf.skin).
    By use the command sil_setup you can access the dll setup. In this you can check if the popup af is active or not, if the preset popup is active or not, and if wished, that the silabs are changed during the search af.
    In the af popup you can put in position the sil_exitaf key through which it is possible to exit from the cycle returning to the original frequency, each function from the outside for the popup can be activated from the manual search key sil_maf.
    In the pre-set popup it is possible to insert pre-set selection keys, the pre-set name label, the pre-set indicators that visualise the miniature pre-set radio, but I recommend inserting also the sil_memory key to enable access to the saving of a pre-set.
    Function Set-up:
    The command sil_setup accesses a form of setup, through which you can access and modify the various values of the plugin configuration.
    You can make the 4 audio channels from the setup form that through the commands of the skin.
    When using the stereo version of the dll usbradio, 4 channels will be ignored.
    Function EON:
    I advise you to superimpose the name label of the radio station eon with it’s indicator, in this way it is possible, clicking on the name, to tune the radio to the eon station desired.
    IMPORTANT:
    You must insert the following command: “CLOSEWINDOW:SDKSilabs | | QUIT” into the ‘quit’ of road runner.
    Dec 2006
    italy, sardinia
    in my first test automatic af would seem to work
    in this test i haven't used the control of probability of the right station but in this first step the program work
    i check if pi is the same and if the actual frequence was not the same of the initial frequence, i need only to reorder the list starting with the greatest probability of the right frequency and then to decrease
    Dec 2006
    italy, sardinia
    in my actual version (1.6) i can use the automatic af
    list of alternate frequence were saved into a file and loaded and sorted usign percentuals of right tuned frequencies
    in the final versione the form is not present
    the only labels refreshed in the form are the list of af and frequencies and percentuals
    no one has written something on this thread lately, is it possible that this thing hasen't caught anybody interest?
    i'm making a plugin similar to iceradio but compatible to last version of rr end with better speed (i thanks the creator of usbradio dualtuner for better speed of rds string)
    Constant Bitrate Beezer's Avatar
    Oct 2006
    It would be nice if you acknowledged your sources.
    Dec 2006
    italy, sardinia
    you can dowload it from:
    http://mio.discoremoto.alice.it/spidermunz
    last code i have upload is for the 1.2
    the name of souce are with "english" inside the name of the zip
    the other file are only the binary of dll
    i upload the 1.6 version soon as possible
    Oct 2006
    Just to be clear, is this your radio DLL or the one coded by Pete, Guino and I here?
    http://code.google.com/p/silabsradiodll/
    Did you use any of our source code?
    Note, I don't actually mind - that's what it's there for, but it would be nice if you acknowledged us.
    Dec 2006
    italy, sardinia
    yes i start from the testsilabdll.exe code
    i convert it into a dll and add some features for the exetended plugin
    look:
    the original version of testsilabdll.exe code is written by RRMOBILE
    you can view this here: http://www.alibri.it/RRMobile/Silab%20USB%20Radio.htm
    i think that the new version of testsilabdll.exe it's the same code written better
    Dec 2006
    italy, sardinia
    version 1.6
    its fix some bugs of old version
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    ill DL it later tonight and try it out. ive never really fully got my radio palyer workign. thanks for your extra work
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
