Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 61
Thread: GPS Heading Indicator Fixed & Upgraded [ Updated 12/10/08 ]
  1. #51
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by rizaydog View Post
    My skin doesn't have a skin.ini. I have a menu.ini but that is it. I don't have a plug-in folder either.
    No,
    Put the settings into the rr.ini file !
  2. #52
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    I hate to be such a pain, but it still doesn't work. I have added and deleted so many things now I don't know where to go. Would you mind taking a look at my code and see if you can find the error(s)?
    Attached Files Attached Files
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
  3. #53
    May 2008
    Bordeaux, France
    If i understand, you use RoadRunner and not Ride Runner ?
  4. #54
    Nov 2007
    North Central PA
    I have Roadrunner in my car. But I have been trying to get this skin with the indicators working on my home pc using bot Roadrunner and Riderunner. I'll use which ever I can to get it to work.
  5. #55
    May 2008
    Bordeaux, France
    Smile
    You put the X,GPSINDFIX into the rr.ini .
    You must to put it into the menu.skin .
    The RRextended folder must to be into the Plugins folder
    Your file are not into a RoadRunner folder and the exe , i think don't like that !
    You have put these two line into the menu.skin.
    They must to be into the rr.ini or skin.ini file , in your case rr.ini file
    GPSIndFolder=Indicators
    GpsIndFix_Enabled=true
  6. #56
    May 2008
    Bordeaux, France
    Smile
    Ok , It's too late this day I give you a good skin tomorrow
  7. #57
    Nov 2007
    North Central PA
    I don't know if it makes a difference but my version of RR didn't have a plugins folder. I just made one there to try to get this to work.
  8. #58
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Holy crap... now I'm confused.
    Cant remember the last time I worked with a RR version that old!
    Plugin works with either RoadRunner or RideRunner, makes no difference. So its either a setting or improper placement of files.
    In your menu.skin, put:
    X,RRExtended
    In your rr.ini, put:
    In your skin folder, make sure you have a 'Indicators' folder with all the GPS arrow png's.
    In any screen that you want to use the indicator, the name is 'HEADING2'. Example:
    I,527,9,32,22,"HEADING2"
    Then of course a GPS port set and GPS attached, for RR to read the GPS data. If done correctly and there is no valid GPS signal, you should see a picture of a satilite with an "X" in the corner
    But if you just use this nicely fixed RR rar'd folder, then all you need to do is...
    *I cleaned up all the files you had everywhere and i deleted the old GPSIndFix plugin
    #1 Unrar it to somewhere
    #2 Go into the xx\RoadRunner\Plugins\RRExtended folder and run the 'Register.cmd'
    #3 Start up RR
    #4 See the indicator that I fixed, on the ALT button.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #59
    Nov 2007
    North Central PA
    Thanks Guys.
    Blue, your rar worked like a charm. I am struggling to understand why I couldn't get this to work. I am sure, at one point, I had it set up like this. The only thing I don't remember is registering the rrextended file. Oh well, I'll play around with it.
    Again, Thanks alot, this is very cool.
  10. #60
    Nov 2007
    North Central PA
    One more problem I found. If I reboot the pc, I have to run the 'Register.cmd' every time. If I hibernate, my xport stops working. And on it goes. . . Any thoughts?
  1. Replies: 353
    Last Post: 08-24-2009, 10:31 AM
  2. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  3. SD Navigation just does not work.
    By rumy in forum StreetDeck
    Last Post: 03-10-2007, 08:11 AM
  4. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  5. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
