Page 1 of 7 1234567 LastLast
Results 1 to 10 of 61
Thread: GPS Heading Indicator Fixed & Upgraded [ Updated 12/10/08 ]
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    So...
    Because of the whole GPS "Heading" indicator not working for the longest time, I decied that a
    fix was in order and created a solution for it as well as improved upon it.
    The changes are as follows:
    #1 New ind is called "Heading2" (just need to do a find/replace all in your skin files)
    #2 Now accepts either jpg or png file extions, it will use whatever is on the N.xxx/N_1.xxx ind graphic
    #3 The ind can also indicate the Signal strength by changing the ind color by the number of satellites,
    meaning...weak(1-4), fair(5-6), good(7+)
    #4 Also uses NA.png for no GPS signal
    How to use the new indicator
    To use the signal strength you must have the additional indicator graphics. These new
    graphic indicator file names are the direction(N,NE,E,SE,S,SW,W,NW) followed by a _x.(jpg/png),
    where x is 1-3 using the above as the guide lines. So "N_1.png" would be north with a weak signal
    where as "SE_3.png" would be southeast with a good satellite signal.
    Settings:
    GPSIndFolder=*
    * - this is the folder name in the skin folder and NOT the whole path, for the extra graphic files or
    if left blank or not used, will look in the dll's path for an "Indicators" folder for the graphics
    I have tested this on all versions from 4/12/07 - Current beta(weather fix), and they all work!
    In the zip, I have included:
    GPSIndFix.dll
    _Install.cmd (to register it)
    _Uninstall.cmd (to unregister it)
    24 iG style Heading2 indicators (26px x 26px) to either use or test with
    1 NA.png for no GPS signal
    This Readme.txt
    If you do not know, you'll need to:
    put the GPSIndFix folder in your "Road Runner\Plugins" folder
    Run the _Install.cmd file
    Put "X,GPSINDFIX" in your menu.skin file, or Plugins.txt file of the skin folder if it has one.
    Any problems just let me know, shouldn't really be any! Or if you have a futher suggestion post that as well.
    Attached Files Attached Files
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    FLAC -zip-'s Avatar
    Ontario/Canada
    OMG this is sooo coool!! TY for taking the time to improve and fix this.
    Sound Stage
    Eclipse|MTX|Infinity
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    NICE! Thanks.
    Could the indicator graphics go in a separate folder?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Updated...
    You can also specify a folder for the indicators to go in by putting "GPSIndFolder=xxxx" in your rr/skin ini file, where xxx is the folder name in the skin folder(not the whole path!)
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Sep 2006
    War-Town, GA.
    Magnificent! Thanks. Makes for a less cluttered skin folder.
    May 2008
    Handholding time...
    So, how would one apply this to the DFX 3.0 skin? Can we get an updater app or something?
    May 2008
    Monday bump.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I just updated this to work with the newer extention plugin indicator standard.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    In the zip, I have included: the ext plugin dll, reg.bat (to register it), and 24 iG style Heading2 indicators (26px x 26px) to either use or test with, and these instructions.
    If you do not know, you need to put the dll and reg.bat files your RoadRunner folder and run reg.bat.
    Put "X,GPSINDFIX" in your menu.skin file.
    I just tried this last night and it didn't work for me. I'm 90% sure it's something I did wrong..
    I'm using DFX4.
    *I downloaded zip file
    *extracted the folder into my DFX skin directory
    *Added "X,GPSINDFIX" (without quotes) to my DFX menu.skin file
    *Put the DLL and bat file in my root roadrunner directory and ran bat file (got succeeded)
    *Added "GPSIndFolder=Heading Inds" (without quotes) to my DFX4 skin.ini file.
    What did I do wrong?
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by tbird2340 View Post
    I'm using DFX4.
    Thanks!
    Define an area in the skin for the indicators to show? maybe?
  1. Replies: 353
    Last Post: 08-24-2009, 10:31 AM
  2. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  3. SD Navigation just does not work.
    By rumy in forum StreetDeck
    Last Post: 03-10-2007, 08:11 AM
  4. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  5. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
