Results 21 to 30 of 36
Thread: Silabs no RDS?
  1. #21
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok i hav'nt played with the new vol controls in the dll as of yet,
    but did you install the usbradio.dll from the links i gave you, and put it in rr root ,thus overwriting the 1 thats already there.
    other wise i think you may need to add a slider or buttons for the silabs vol.
    you can get those from the skin cmds in the dll downloaded.
    also did you add the folder and contents " Testsilabsconfig" to rr root as well.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #22
    Feb 2008
    Hi,
    Still no ck.
    I can see that the radio is playing fine in the skin and that Vista shows the USB as radio and shows the volume indicator moving to the sound from the radio but the sound is just not being sent to winamp or speakers etc. all other sounds work fine
  3. #23
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    its a long shot but if you are using the cmds from my skin file, you will see silabs has its own mute, try that ,
    just another thought what usbradio.dll did you put in the rr folder was stereo or quad
  4. #24
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    remebered another part of the set up may cure your problem
    in the download there is a zip called justvcredist_x86(1) run this then try again.
  5. #25
    Feb 2008
    Hi,
    Just re-run vcredist_x86(1).exe and still no differnt, starting to thing that in might be a formart pc and start again
  6. #26
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    no its not that bad, just done a test myself the usbradio.dll in the downloads theres a problem have you got the latest usbradio.dll from the update which JohnWPB posted use that 1 and reboot system and all should be good it worked for me to get sound back
  7. #27
    Feb 2008
    Hi,
    Where is the dll to download? Will try it.
  8. #28
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    same again remove .txt
    Attached Files Attached Files
  9. #29
    Feb 2008
    Copied and pasted, now the radio doesnt show RDS or anything and still no sound.
    Could it be anything to do with any settings in rr or winamp?
  10. #30
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    rdstxt may take a minute or so , depending on your signal,
    as for the sound ,which i did get, when i swapped usbradio.dll 1 was 128k (gunios)
    the other is 47k ,the 128k ,on which i restarted computer and sound was back.
    other than that i'm at a loss.
  1. Expansion of RDS functions on SiLABs Radio?
    By Sinobi in forum Road Runner
    Last Post: 11-05-2007, 12:10 PM
  2. For Guino: USB Radio FM with RDS from Silabs
    By antonio_riq in forum Road Runner
    Last Post: 10-17-2007, 07:35 AM
  3. Replies: 70
    Last Post: 10-15-2007, 05:21 PM
  4. INNOVATEK IN-4301DTM RDS problem
    By lmontoya in forum General MP3Car Discussion
    Last Post: 08-17-2007, 02:31 PM
  5. RDS, ID3 and MP3
    By fearthepenguin in forum General Hardware Discussion
    Last Post: 09-24-2005, 11:22 PM
