Results 1 to 9 of 9
Thread: Plugin?
    Jun 2003
    Memphis - TN
    Plugin?
    Is there a way to have audio from 2 different sources streamed to different speakers?
    Such as MP3/XM audio to the fronts, movie audio to the rears?
    I'm wanting to set up a dual monitor setup so my kid can watch a movie on a headrest monitor, and I turn on the movie from up front. Possible?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Custommx3 View Post
    no way to handle this in RR, but you can set up winamp to handle multiple instances, then set each instance to use two separate sound cards. So you can have MP3 playing on primary sound card on first instance of winamp, then have XM (thru winamps line-in plugin) playing from the second sound card from the second winamp source. Sounds like a fun wiring job huh.
    Live mp3Car Facebook Chat
    Jun 2003
    Memphis - TN
    well, if I can run multiple instances of winamp, couldnt I run a plugin to direct sound to the fronts via one instance and sound to the rears with the second instance, and just "y" the audio to the Audion input. Now that I think about it probably not, cause I dont think the audio "split" is done with the cables. In other words there is no Front/rear input via cables.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You will need two soundcards, two instances of winamp, and probably two instances of RoadRunner.
    Well that's what I am going to test on my mirror carpc as soon as I finish installing the drivers
    Jun 2003
    Memphis - TN
    Only problem, is that I want to be able to play the movies on the second screen, controlling it from the first
    Jun 2003
    Memphis - TN
    Thanks!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Thanks!
    I actually put them there for me, so I don't have to go searching for them again
  1. Custom Indicator Bug
    By JohnWPB in forum RR Bug Tracker
    Last Post: 03-27-2008, 06:10 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
