Results 1 to 4 of 4
Thread: Masquerading skinned application
    Jul 2006
    Brisbane, Australia
    Hi guys,
    I wonder if anybody has got any ideas about this.
    We want to embed OzieExplorer, a topographcial mapping application into RR. When doing this from RR, Ozie is not very well behaved if embedded in RR and we are close to completing a Skinbedder skin for it. See OziExplorer
    Ozie has an interface DLL and I am considering writing a RR plugin for it using Visual C as being able to access some features from RR will also be very useful. This DLL requires the Ozie application to be open and communicates with Ozie using the same WM_COPYDATA messaging that RR uses. However, once the OziExplorer application is embedded in Skinbedder, its window name and class disappears so it can't be found.
    I think the only solution around this problem is that the RR Plugin needs to open a hidden window with the same class and name details as the Oziexplorer application (so the Ozie DLL can find an application) and intercept the messages from the Ozie DLL and redirect them to Skinbedder.
    Ani ideas, thoughts or sample code would be appreciated.
    Rod
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I know absolutely nothing about Visual C, but I do know that AutoIt has an option to look for child windows (Such as just about any program that is embedded into RR is)
    There is most likely a way to do the same thing in Visual C.
    There is also the option to look for the window handle, instead of just the name.
    In AutoIt for instance the command is: Opt("WinSearchChildren", 2).
    I am clueless to Visual C, but hopefully that will give you a direction to look get it to work.
    My Fiero Build Thread
    Jul 2006
    Brisbane, Australia
    Thanks John, that is useful info. I tracked it down in VC
    So the approach will be to:
    1. use FindWindow to find the toplevel window handle (in this case SkinBedder)
    2. use FindWindowEx to find the child window (in this case OzieExplorer)
    3. Raise a new window with the same name and class as the OziExplorer
    4. Capture the WM_COPYDATA messages that the Ozi DLL sends to the OziExplorer application. Still researcing that one, but I got some sample code somewhere
    Rod
    Jul 2006
    Brisbane, Australia
    Thanks for the tip, I got this working, It was simply a matter of opening a window, drilling own into Skinbedder a couple of levels to find the window I needed and then using the Windows messaging loop to relay messages each way. I am doing thi sin a simple application that opens a window.
    Now all I need to do is write the DLL. Hopefully I can move the magic window into the DLL so I don't need to have a separate window open to do the magic.
    Here is the message processing code:
    Code:
    	case WM_COPYDATA:
    		cd = (PCOPYDATASTRUCT) lParam;
    		if(hWnd == Ozi){
    			// The data has come from Ozie, send to the DLL
    			RetVal = SendMessage(OziDLL,WM_COPYDATA, wParam, lParam);
    			return RetVal;
    		else{
    			// Not from Sb, must be from DLL
    			OziDLL = hWnd;	// Save the DLL handle
    			RetVal = SendMessage(Ozi,WM_COPYDATA, wParam, lParam);
    			return RetVal;
    		break;
    And here is the code to dig out the window.
    Code:
       Sb = FindWindow(NULL,"OziEmbedded"); //SB Window Title
       if(Sb){
    		OziWindow = FindWindowEx(Sb,NULL,"TWindowContainer","OZIWINDOW");  //SB  embed statement
    		if (OziWindow){
    			Ozi = FindWindowEx(OziWindow,NULL,"TfmMainForm",NULL); //The Window we want
    Rod
  1. Skin Embedding Application Problem
    By JohnWPB in forum Road Runner
    Last Post: 04-19-2008, 05:41 PM
  2. Replies: 5
    Last Post: 01-20-2007, 12:55 AM
  3. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  4. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 04:44 AM
  5. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 01:35 PM
