Page 12 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 111 to 120 of 149
Thread: Coverjuke, (openGL)
  1. #111
    Dec 2007
    Thanks for the update.
    Is ilist using openGL too?
  2. #112
    Dec 2007
    man... coverjuke in rr is just weird......
    I had them working fine both video and audio at the same time.. Suddenly, I can't only run either one of them in RR. any time i run second one, cpu go crazy... But, i don't experience this problem outside RR... maybe the AI problem.... what's the problem with the following script? this is for audio.. believe or not, it was working...
    Opt ("wintitlematchmode", 2)
    if WinExists("coverjukeA") then
    WinActivate("coverjukeA")
    ;$Cvrj = WinGetHandle("coverjukeA") ;grab coverjuke.
    ;$var = IniReadSection($skinpath & "skin.ini", "coverjukeload")
    ;WinMove($Cvrj, "", $var[1][1], $var[2][1]) ;move coverjuke in a way that fits the screen and is not in the way.
    Exit
    EndIf
    run("coverjuke.exe") ;after all is good open up coverjuke.
    WinWait("coverjukeA", "", 10) ;wait untill coverjuke is running.
    if $Cvrj = "" Then ;if no success exit.
    Exit
    Else
    WinMove($Cvrj, "",690, 185)
    EndIf
  3. #113
    Dec 2007
    ok.. this might be a bug... now, it happens outside rr.. it's very inconsistent... when I tried to run the second instance, cpu spikes up and behaves like as if there's a memory leak...
  4. #114
    Dec 2007
    shoot.. this drives me nuts.. What's going on with this... Check this out. This script runs fine by double clicking it, it launches coverjuke for audio with a window name i want.. i am not even loading rr... That's outside RR... now i call this script in RR with this command in exectbl.ini,
    "COVERJUKEaudio","LOAD;coverjuke.skin;!freeglut;$R RPATH$Coverjuke_audio\CoverJukeload.exe;||SETTOPMO ST;RR;TRUE"
    cpu spikes up 100% and coverjuke launches but with no image.... what in the world...
    I just can't figure out why and i am going nuts now... anybody have any suggestions? This new version is giving me some hell... try to make this work for both video and audio is just presenting me with all kinda inconsistent problem... I never had this problem before... by the way, funny thing is video is still working fine.. and they are same scripts except window name and different ini setting...
    Exit
    EndIf
    if $Cvrj = "" Then Exit
    Else
    EndIf
  5. #115
    Dec 2007
    the new version without any doubt loads the contents faster than prev. ver. but, i am having a such hard time with its inconsistency when using with RR.. As standalone, it's nearly perfect... So, what's the reason this doesn't embed into RR like other app?
  6. #116
    Constant Bitrate Beezer's Avatar
    Oct 2006
    I have found a bug in CoverJuke. If the album directory contains a corrupt jpg file, then all the images are off by one.
  7. #117
    Dec 2007
    AI help needed...
    try to send commandline param to AI script..
    this is what have in exectbl,
    "COVERJUKEVideo","LOAD;coverjukeVideo.skin;CoverJU ke;$RRPATH$Coverjuke\Coverjukeload.exe V;||SETTOPMOST;RR;TRUE"
    I am sending "V" as a param.. when i run the script, i get an error,
    line -1 "error parsing function call"... What am i doing wrong here...
    Also, what's the RR variable name for videopath? for audio, "$musicpath$, what about video? I tried "$videopath$", i don't think that is it..
  8. #118
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Code:
    "COVERJUKEVideo","LOAD;coverjukeVideo.skin;CoverJUke;$RRPATH$Coverjuke\Coverjukeload.exe|V;||SETTOPMOST;RR;TRUE"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  9. #119
    Dec 2007
    Thanks Sal.. i am still getting the same error.. it doesn't like this,
    CMDLINE[1]
    isn't it what is used to parse the param value?
  10. #120
    Dec 2007
    ok... looks like $CmdLineRaw is not giving me any issue.. That's taken cared of..
    I have a question, what exactly does this line do?
    "ONEXIT","CLOSEWINDOW;coverJuke"
    What i understood, it kills coverjuke, however in my case, it's not.. Well it kinda.. i mean i don't see the process under task manager and it's gone from RR screen, but there's a reason why i am saying it's not gone completely.. i go to video coverjuke then exit which kills the coverjuke... I then go to audio coverjuke, it's hanging... and vise versa. Now, if i go to audio coverjuke and exit out of RR and restart, i can then go to video coverjuke.. i have to completely exit rr in order to run different coverjuke... So, it looks like something is left from running last instance of coverjuke that's interfering with new instance of coverjuke...
    There's something about running multiple coverjukes that RR or converjuke does not like.... In my last case, i am not even trying to run multiple.. i kill one before i even start a new one, but still having an issue... It's driving nuts.
  1. clutter opengl toolkit - for the next gen carpc frontend
    By tripzero in forum Software & Software Development
    Last Post: 06-20-2008, 01:14 AM
  2. Help! OpenGL on Debian, VIA EPIA M10000
    By debian00b in forum Linux
    Last Post: 05-22-2006, 09:54 PM
