Page 9 of 15 FirstFirst 123456789101112131415 LastLast
Results 81 to 90 of 148
Thread: Coverjuke, (openGL)
  1. #81
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you can change the angle and size of the images , even how many either side of the centre in the ini
  2. #82
    Dec 2007
    Quote Originally Posted by MGD View Post
    Good old ASTRO looking good
    That's right... i am using ur skin for htpc... I modified a little... love it...
    carputer1,
    all i see is this,
    spacealbum = 3.499999
    zoomalbum = 1.200000
    albumangle = 70
    zoomscene = -7.250000
    verticalangle = 15
    horizontalangle = 360
    doesn't really tell me which is for width and height..
    by the way, i might ask the author to recompile the exe(video version) with different window name... then my problem solved...
  3. #83
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    play with zoomscene and zoomalbum i know i played with these reduce zoomscene=-4.250001 , should make the art bigger , well you'll find out .
  4. #84
    Dec 2007
    Thanks... zoomalbum made it bigger... good enuf...
  5. #85
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    you can also use the "function" keys ...
    use "alt" and up/down arrows for zoom in/out all albums
    use "alt" and left/right arrow to zoom in out main album only.
    use "ctrl" and left/right to rotate the display left / right
    use "ctrl" up arrow to change perspective to over the albums
    use "shift" and up/down to vary the spacing between the side albums.
    these jeys work if you run CJ ouside RR, and it wil lsave them on exit for use the next time you run inside RR ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  6. #86
    Dec 2007
    how convenient.... Thanks Valheru
  7. #87
    Dec 2007
    guys.. what's the correct syntax here...
    "cjPotPlayer","load;generic.skin;Enjoy Your Movie;C:\Program Files\Daum\PotPlayer\PotPlayerMini.exe $COVERJUKEPATH$;!PotPlayer"
    Trying to play a movie using something called potplayer.... potplayer opens fine but doesn't play the movie which tells me syntax is probably off at $COVERJUKEPATH$..
  8. #88
    Dec 2007
    ok, i got the above thing resolved.... now i try to use send key to switch to a full screen... control + alt + enter will do it and works from keyboard... but wouldn't work with the below command... What am i doing wrong here..
    "cjPotPlayer","load;blank.skin;!potplayer;C:\Progr am Files\Daum\PotPlayer\PotPlayerMini.exe|$COVERJUKEP ATH$||SENDKEY;^%{ENTER};!PotPlayer"
  9. #89
    Jul 2007
    Ireland
    Quote Originally Posted by brandensin View Post
    "cjPotPlayer","load;generic.skin;Enjoy Your Movie;C:\Program Files\Daum\PotPlayer\PotPlayerMini.exe|$COVERJUKEP ATH$;PotPlayer"
    but thats assuming that "$COVERJUKEPATH$" have the full path and file name of the video you want to play
  10. #90
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by Valheru View Post
    Right. $coverjukepath$ is the path to the folder only.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  1. clutter opengl toolkit - for the next gen carpc frontend
    By tripzero in forum Software & Software Development
    Last Post: 06-20-2008, 01:14 AM
  2. Help! OpenGL on Debian, VIA EPIA M10000
    By debian00b in forum Linux
    Last Post: 05-22-2006, 09:54 PM
