Results 1 to 2 of 2
Thread: RRExtension with lists
    Newbie Lucifer's Avatar
    Aug 2004
    Belgium
    I would like to make a RRExtension dll that uses a list object.
    In a RRExtension.vb is there a way to catch a click on a list item and set the text of a label or editbox (with a value that is associated with that item)
    In the skin I want to do this:
    define a list (which one do I use? PL, S...)
    define 2 buttons to go one item up and down
    define a editbox
    Thus, is there something like a ReturnList? or could I do this with the processcommand and use the frm parameter to get to the list object or item?
    How would i set the text of a label?
    Cheers,
    Morex 3688 (Via MII10000 - 512Mb - 2,5HD 30Gb DVD+RW)
    CarTFT Motorized 7" In-dash Touchscreen
    CNX 1260
    Current Status: Skinning !
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    just use a custom list thats built into rr. CLADD and CLCLEAR are the commands u'll use and (SC) is the object you need. If you need to change the ONCLCLICK event in your plugin you can just define it in process command. That will override the whatever the default may be
    Live mp3Car Facebook Chat
  1. is having two custom lists on one skin possible?
    By Sonicxtacy02 in forum RR Skins
    Last Post: 03-19-2008, 02:19 PM
  2. Replies: 5
    Last Post: 12-10-2007, 04:36 PM
  3. How do I use Custom Lists?
    By Sal R. in forum Road Runner
    Last Post: 11-01-2007, 10:15 AM
  4. Dual lists
    By 1Munkey in forum Road Runner
    Last Post: 09-24-2006, 01:55 PM
  5. Problem with places in lists
    By JosepZ in forum Map Monkey
    Last Post: 01-22-2005, 07:41 PM
